ruteger Posted September 25, 2012 Share Posted September 25, 2012 Well, my radio quit working for a while tonight. It appeared to turn on but locked onto frquency '106.5' and couldn't be tuned to anything else no matter what I tried. It would turn on and off, but that's it Turned the car off, let it sit for a few minutes, then it came back on. Quote Link to comment Share on other sites More sharing options...
TDMAN Posted September 25, 2012 Share Posted September 25, 2012 Boy, some of you are really trying to create a conspiracy here. Let's see, based on information compiled here and at the Edmunds forum, so far there are reports of what, three, or four leaking roofs. A problem if you have one, but far from wide spread. And robots don't know what day it is. Well said, I agree! Quote Link to comment Share on other sites More sharing options...
pillboy Posted September 25, 2012 Share Posted September 25, 2012 (edited) Conspiracy, innuendo, skull-duggery, tom-foolery, a$$-hattery...these are all required in a car forum. Didn't you guys read the fine print when you signed up? And speaking of fine print...PJ, you have to get a handle on your font sizes when you cut and paste. Edited September 25, 2012 by pillboy Quote Link to comment Share on other sites More sharing options...
seamusbleu Posted September 25, 2012 Share Posted September 25, 2012 Speaking of BUILD DATES - CyberDMan reports mine is scheduled for Oct-06. ................................... uh.....that's a Saturday. Huh? How do you find out your scheduled (or for that matter, actual) build date? Quote Link to comment Share on other sites More sharing options...
PajamaGuy Posted September 26, 2012 Share Posted September 26, 2012 Go back up to Blue Oval Forums index, then down to Ford Employee Forum, and Vehicle Locator By Ford Employees. Read the rules, and post your data. They'll answer you once a week. Once you have your VIN, you can get your window sticker (when it's available), and on it is the BLEND (build) date. Quote Link to comment Share on other sites More sharing options...
inswva Posted September 26, 2012 Share Posted September 26, 2012 Build date of 6/18/2012 for my Escape. It has the panaroma roof and roof rack. No leaks so far. /knocks on wood Quote Link to comment Share on other sites More sharing options...
seamusbleu Posted September 26, 2012 Share Posted September 26, 2012 Go back up to Blue Oval Forums index, then down to Ford Employee Forum, and Vehicle Locator By Ford Employees. Read the rules, and post your data. They'll answer you once a week. Once you have your VIN, you can get your window sticker (when it's available), and on it is the BLEND (build) date. Thanks PJ. My window sticker just showed up. I wouldn't have known the number above the word BLEND was a date without your comment, above. Looks like Tuesday for me - hopefully a good day for the "caulkers". Quote Link to comment Share on other sites More sharing options...
RitchieD Posted September 26, 2012 Share Posted September 26, 2012 I have the mysterious leak too. The dealer did a water test and says there is no leak. However, both times it has rained (only had car 9 days) the fabric above the plastic on the post between the windshield and the door gets soaked inside. No water anywhere else. Yesterday I took a garden hose and flooded the roof around the roof rack and the windshield and no water got it. Waiting for next rain to see what happens. I do NOT have sun roof. Quote Link to comment Share on other sites More sharing options...
blockisle9 Posted September 27, 2012 Share Posted September 27, 2012 (edited) You can easily stripe out the threads on the oil pan. The are no longer steel. Changing the crush washer is as important.Filters usually don't have a torque value was the filter adapter would thrown that value off.Service manuals usually state a half or three quarter turn past seating. Edited September 27, 2012 by blockisle9 Quote Link to comment Share on other sites More sharing options...
blockisle9 Posted September 27, 2012 Share Posted September 27, 2012 I have to ask? These water leak issues, did they develope over time. Or from day one? I wonder how wide spread this is. Has anyone had the problem found and repaired? Just wondering... Thanks Quote Link to comment Share on other sites More sharing options...
RitchieD Posted September 27, 2012 Share Posted September 27, 2012 The water leaks appear to be rare. They come from the factory with the problem. I have read of no solution or accurate dianogisis. yet Quote Link to comment Share on other sites More sharing options...
pillboy Posted September 27, 2012 Share Posted September 27, 2012 Has anyone having water leaks also taken off their roof rack cross bars and NOT put bolts into the holes left in the rails? Quote Link to comment Share on other sites More sharing options...
RitchieD Posted September 27, 2012 Share Posted September 27, 2012 What are you thinking? I can try it. Quote Link to comment Share on other sites More sharing options...
pillboy Posted September 27, 2012 Share Posted September 27, 2012 I took my cross bars off, but I plugged the holes with nylon bolts. The roof rails have to be hollow. If the holes are left open, maybe rain water is getting into the inside of the rails when the car is driven and then leaking into the inside of the roof cavity. Just a thought. I have hand washed ours, but have yet to drive it in the rain. Quote Link to comment Share on other sites More sharing options...
transitman Posted September 27, 2012 Share Posted September 27, 2012 I have removed my cross bars and have not plugged the holes. Last week while driving through Louisiana and Mississippi, I encountered 7 hours of steady downpour, once it was raining so hard I had to pull off the road. No water leaked into my car. I understand where you are coming from here with X-bars and misaligned doors. As we all know, water seeks it's own level, flows down hill and travels the path of least resistance. This water may be entering the car a a location no one would expect and flowing to the front. Quote Link to comment Share on other sites More sharing options...
pillboy Posted September 27, 2012 Share Posted September 27, 2012 Water would flow forward upon braking and I have to believe most owners generate more forward G's under braking as opposed to reward G's under acceleration. Quote Link to comment Share on other sites More sharing options...
svtenthusiast Posted September 27, 2012 Share Posted September 27, 2012 (edited) I have removed my cross rail bars from day one (in July) and have not had any leaks. Added: I didn't plug the holes with anything, but would like to find some silver plugs similar to what they are already using (part not available seperately according to the Ford computer) Edited September 27, 2012 by svtenthusiast Quote Link to comment Share on other sites More sharing options...
PajamaGuy Posted September 27, 2012 Share Posted September 27, 2012 PillBoy, Where/what did you get to plug the holes? Quote Link to comment Share on other sites More sharing options...
Escapism Posted September 27, 2012 Share Posted September 27, 2012 PillBoy, Where/what did you get to plug the holes? Here at work McMaster Carr is my best friend for hardware. Quote Link to comment Share on other sites More sharing options...
pillboy Posted September 27, 2012 Share Posted September 27, 2012 (edited) PillBoy, Where/what did you get to plug the holes? I just bought some M6 (1.0 pitch) X 10mm white, nylon hex-head bolts off eBay (just search "M6 nylon bolt" - there are still listings). They came from China (pretty quickly too). I originally got some stainless steel ones from the local hardware store but decided I was gonna have to Loctite them in as I did not want them working themselves loose and taking a trip across the paint on the roof at highway speed. I am happy with the fit and I was able to tighten them sufficiently so I am not worried about them coming out (and I doubt they would damage the paint if they did). The factory Torx-head fasteners (the ones withOUT the wings) did have thread locker applied to them. The white nylon blends well with the silver roof rails and no one will ever notice them. Edited September 27, 2012 by pillboy Quote Link to comment Share on other sites More sharing options...
PajamaGuy Posted September 27, 2012 Share Posted September 27, 2012 (edited) Check this out: http://www.amazon.co...s=M6 nylon bolt If these are it, I'll buy them (100) and if anyone else wants some, it will just cost the postage. (...while supplies last... ) Edited September 27, 2012 by PajamaGuy Quote Link to comment Share on other sites More sharing options...
pillboy Posted September 27, 2012 Share Posted September 27, 2012 Super price. I bought a package of 20 (you need 5 for each rail) for $5.99 with free shipping...all the way from China. Quote Link to comment Share on other sites More sharing options...
Ford Escaper Posted October 23, 2012 Share Posted October 23, 2012 (edited) Based upon all that I was reading about roof leaks, I put Titanium with roof rack and sunroof outside on the driveway because it was raining. Sure enough in the morning, there was water on the driver's seat and a leak coming out of the pillar just where other people have described it. I took it to the dealer and they said that it was the caulking around the front window and they could see where the water was coming in. They had a glass person come and recaulk it. Still leaked. Now they are taking out the windshield and checking the welding. I will see if that does anything but from what I have been reading, it doesn't. Will report on what happens but would appreciate learning if anything that the dealer did fixed the issue for any of you out there. Manufactured 6/12/12 Edited October 25, 2012 by Ford Escaper Quote Link to comment Share on other sites More sharing options...
pillboy Posted October 23, 2012 Share Posted October 23, 2012 Nice...leaking windshields. My no-sunroof-smugness has just evaporated. Quote Link to comment Share on other sites More sharing options...
davidg716 Posted October 24, 2012 Share Posted October 24, 2012 June was the month when most of the leaky escapes were Mfg'ed right? Quote Link to comment Share on other sites More sharing options...
