Drewbob Posted August 29, 2019 Share Posted August 29, 2019 SOMEONE HELP ! 2012 FORD FOCUS CRANKSHAFT SENSOR WAS BROKEN I REPLACED IT AND STILL WONT START. IM GETTING CODES ... P0320 engine distributor engine speed input circuit P1674 electrical feedback did not mirror rising degree P1450 fuel tank vacuum cannot bleed Also ... Is there a special procedure to replace these?? Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 29, 2019 Share Posted August 29, 2019 @fordtech1 is your man for this. Quote Link to comment Share on other sites More sharing options...
Drewbob Posted August 29, 2019 Author Share Posted August 29, 2019 3 hours ago, twintornados said: @fordtech1 is your man for this. My man ? Quote Link to comment Share on other sites More sharing options...
YT90SC Posted August 29, 2019 Share Posted August 29, 2019 (edited) You need 2 special service tools to install the sensor. Pin for the crank, locator for the sensor. You can't eyeball it. If the sensor was damaged, are all the teeth on the balancer intact and not bent? There is NO keyway for the crank pulley. If you loosen it's bolt, you're not gonna get it to restart without even more special service tools. The P1450 is most likely the cannister purge solenoid. P1674 is an odd code. The software in the PCM is corrupt. Have you tried jump starting it, or programming the PCM in any way? Have you had the fuel tank deformation recall completed? If not, that *should* cover the P1450 and might take care of the P1674 as the PCM has to be programmed for the recall. Edited August 29, 2019 by YT90SC Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted August 30, 2019 Share Posted August 30, 2019 YT90SC is correct. He hit it on the head. I’ve been in training so not had a lot of time to be online. But he answered the same as I would. Quote Link to comment Share on other sites More sharing options...
twintornados Posted August 30, 2019 Share Posted August 30, 2019 13 hours ago, Drewbob said: My man ? Yes, him or the other tech here, YT90SC () ....they both know their stuff under the hoods of the various Ford products and help out often. Quote Link to comment Share on other sites More sharing options...
