Everything posted by ESP08
2024 Mustang To Be Revealed At Detroit Auto Show
ESP08 replied to Trader 10's topic in Ford Motor Company Discussion Forum
They are indeed pretty drastically different. Also photos of both have been posted already so perhaps you should read the "entire" thread before commenting and violating your own "pet peeves". -
I'm glad you like the 18 headlights. You are in the minority -
Looks, I thought I'd get used to them with time but honestly only dislike them more as time goes on. Ford keeping the previous headlights on the GT350 and GT500 says a lot. -
The 2018 headlights are terrible, nice car otherwise... -
Raptor R Confirmed with 5.2L V8
ESP08 replied to silvrsvt's topic in Ford Motor Company Discussion Forum
https://www.donaldson.com/en-au/engine/filters/products/air-intake/cleaners/psd/ -
Ram pretty clearly intended to make a functional hood scoop as the primary design criteria for that inlet system. Nothing special about it in the least as it uses pedestrian panel filters just every other OEM. If Ford wanted to one up them they should employ a large Donaldson Powercore filter that could easily provide drastically superior air filtration and and more flow with a less convoluted inlet tract. https://www.donaldson.com/en-us/engine/filters/products/air-intake/replacement-filters/powercore-filters/ -
Yeah, those four inner lights have strong Silverado vibes. I would have preferred a take on the 21 F150 headlights
I'm sorry I increased your daily mouse clicks. In the meantime, I will comment when something occurs to me and if another poster has made a similar comment so be it. Perhaps you should get over yourself
Air filters FTW -
Oh geez, I bet they are going to start doing that to bring some continuity with the EVs.
Yeah and you can clearly hear converter lockup. Not a DCT -
I wasn't arguing that Ford should have engineered a TT for Raptor, but rather I would have liked to have seen Predator be a 5.0 or 5.2 EcoBoost from the get go. -
The 5.4 used a 22 heat range and the 4.6 used 32s, but the plugs are fully interchangeable. If this was an engine swap project I'd be surprised if he's using OE Motorcraft 22s in the 5.4, never know though I guess. The 5.4 is physically wider, if it's still using the Mustang GT-style intake manifold do you see any adapter plates between the intake and heads? How wide is the engine cam cover to cam cover?
I see what you're saying, the main thing I took issue with was comparing the Gen 3 Hemi favorably to the Coyote when Coyote has just accomplished so much more in virtually all performance arenas. I would have preferred a high performance EcoBoost 5.0 to the Predator. In fact I was hoping the GT500 would get a twin-injected twin turbo 5.0 and was disappointed when they stuck with the blower. -
Yeah, the Hellcats use Twin Screw blowers which have ~4 thousandths rotor to case clearance. It's not a problem with proper air filtration. The Trinity and Predator both use TVS blowers which generally have superior durability (and service life) characteristics to Twin Screws because both rotors spin the same speed. The Twin Screw has one rotor that spins much faster than the other which reduces maximum rotor speed capabilities. The TVS can spin 24,000 rpm Twin Screws 18,000, any more and rotor flex begins to cause some internal contact Despite the 5.2's bore center constraints it more than holds it own with the blown 6.2 Hemis: Hellcat 6.2 - 2.4L Twin Screw - 12 psi - 707 HP / 650 TQ Hellcat Redeye 6.2 - 2.7L Twin Screw - 15 psi - 797 HP / 707 TQ Predator 5.2 - 2.6 TVS - 12 psi - 760 HP / 625 TQ I'd dare say it requires less work/mods/boost to make 900+ rwhp with the GT500 5.2 than it does with either version of the Hellcat 6.2. -
Huh? Predator is actually 3.7" bore diameters. The Mopar has demonstrated no such advantages in the aftermarket, FYI. I've seen Coyote blocks taken to MUCH higher power levels than I have stock Gen 3 Hemi blocks. There's a reason why there is aftermarket demand for stronger (cast) Gen 3 Hemi blocks while the only aftermarket Coyote blocks are full billet blocks ready for 3000-4000 HP. That because the Hemi casting is structurally tapped out in the 1300 rwhp range and the Coyote isn't. What is Dodge going to respond with? The Redeye has a 2.7 liter Twin Screw blower making 15 psi and makes 797. The Predator with a 2.6 @ 11 psi makes 760. The Predator is a better performance platform than the Hellcat IMO... and the Raptor is lighter. -
It would be difficult to ge TiVCT 4-valve 6.8 with a TVS supercharger to make less than 900 crank. Unless it’s a surprise of the century it’s gotta be a 5.2.
I think so. Ford has committed 5.0 production to Essex for the foreseeable future and Ford just invested money in the Gen 4 Coyote (cylinder deactivation) for the 21 MY F150. I just can't see a Godzilla 6.8 directly replacing the 5.0.
Anyone disappointed by the Predator just can't be aware of their performance capabilities with just basic bolt-ons and a tune. These things can make 900-1000 rwhp easily all without ever cracking a cam cover and with stock-like drivability. The Predator is bad... and yes they make power easier than the larger Hellcat mod-for-mod. -
Wards 10 Best Interiors for '22
ESP08 replied to ANTAUS's topic in Ford Motor Company Discussion Forum
Exactly
