TomServo92 Posted April 29, 2009 Share Posted April 29, 2009 Link Quote Link to comment Share on other sites More sharing options...
7Mary3 Posted April 29, 2009 Share Posted April 29, 2009 Neat! Wonder where the radius arms went.......... Quote Link to comment Share on other sites More sharing options...
ANTAUS Posted April 29, 2009 Share Posted April 29, 2009 Neat! Wonder where the radius arms went.......... Maybe the "Radius" arms did a 180 ? Quote Link to comment Share on other sites More sharing options...
twintornados Posted April 29, 2009 Share Posted April 29, 2009 Neat! Wonder where the radius arms went.......... theoldwizard stole 'em for his Econoline Quote Link to comment Share on other sites More sharing options...
351cid Posted April 29, 2009 Share Posted April 29, 2009 Who ever wrote this up has never experienced the "weak" 6.8L V-10. I suspect that 457 lb ft will still trump the 400 lb ft offered in the 6.2L. That is assuming that the 400/400 numbers are correct. Quote Link to comment Share on other sites More sharing options...
old_fairmont_wagon Posted April 29, 2009 Share Posted April 29, 2009 I'm not as impressed with the 6.2L as I thought I once was. If it can't match or surpass the power and torque output of the old 2V 6.8L V-10, I'm afraid that it'll be a step back for that market segment for Ford. However, if we consider this more of a merging of the 5.4L and 6.8L products into one, then splitting the difference won't be too bad. I'd still like to see 420+ lbs of torque in that segment, though. As long as the HP numbers are at least as good as the 2V 6.8L V-10s, I can't see where it would be a failure. Quote Link to comment Share on other sites More sharing options...
jpvbs Posted April 29, 2009 Share Posted April 29, 2009 I believe the 6.2 will also come with a 6 speed auto. A deeper first gear and with closer ratios should help make up for the loss of torque. The 6.2 in the HD GM trucks only comes with about 360 HP doesn't it? Quote Link to comment Share on other sites More sharing options...
7Mary3 Posted April 30, 2009 Share Posted April 30, 2009 I believe the 6.2 will also come with a 6 speed auto. A deeper first gear and with closer ratios should help make up for the loss of torque. The 6.2 in the HD GM trucks only comes with about 360 HP doesn't it? GM does not offer the 6.2L in any of the HD's. The HD's get a 360 h.p./380 ft. lbs. 6.0L. However, the LS series engines can go to 7.0L if need be. Before GM got into trouble, a larger truck only LS was rumored to be in the works. Don't know what the statusof that engine is at the moment.i Quote Link to comment Share on other sites More sharing options...
White99GT Posted April 30, 2009 Share Posted April 30, 2009 I really hope the 400/400 numbers are sandbagged. I'm hoping for 420/440 at least. Quote Link to comment Share on other sites More sharing options...
NLPRacing Posted April 30, 2009 Share Posted April 30, 2009 I really hope the 400/400 numbers are sandbagged. I'm hoping for 420/440 at least. Me too. I don't see only 400 lb/ft doing well in a Class A motorhome compared to the current 3V 6.8L/5 speed auto combo, even with a 6 speed auto. Quote Link to comment Share on other sites More sharing options...
351cid Posted April 30, 2009 Share Posted April 30, 2009 The Class A motorhome still gets the old 2V 6.8L V-10. That engine is rated at 310 hp (305 in a van) and 425 lb ft. The 3V engine (2005 and up) is rated at 362 hp and 457 lb ft. The 2V seems to be more fuel efficient, but from what I've experienced the 3V has a very noticable power increase...coupled with the 2V using the 4 sp auto only. Quote Link to comment Share on other sites More sharing options...
