FPV launches Coyote V8 as Miami
GT500 here it comes!
Nah, look out for more cubes (than what the GT500 currently has). A famous number, too.
I was told there were two engine projects, "Hollywood" and "Miami"
Hollywood (North American) for lighter Mustang and Auto/manual transmissions.
Miami (Australian) for heavier Falcon and ZF transmission.
"Hollywood" was the 6.2 litre Boss in the Falcon, along with the US' auto box to go with it. That was scrapped for "Miami".
Saintlaz1, it's the project name.
The below is from another forum... courtesy of JPFS1
BASE ENGINE SYSTEM TECHNICAL SPECIFICATIONS
Bore: 92.2mm
Stroke: 92.7mm
Con-rod Length: 150.7mm
Compression ratio: 9.25:1
New Firing Order for reduced crankshaft and engine vibration
1' date=' 5, 4, 8, 6, 3, 7, 2
[b']Engine Block[/b]
Aluminium deep skirted block
6-bolt cross bolted mains
steel press in cylinder liners
piston squirting jets for low piston temps and increased durability
Cylinder Heads
high-flow 4 valve
DOHC
32V
roller finger followers
pent roof combustion chambers
55.98cc combustion chamber volumes
Valve Train
intake valves
o 2 x 37mm
o chrome plated steel material
exhaust valves
o 2 x 31mm
o high temp. chrome plated inconel material
12mm intake valve lift
11mm exhaust valve lift
chain-driven cam drive system
variable intake valve timing
fixed exhaust valve timing
common intake and exhaust valve springs, retainers, collets, seals
Crankshaft
forged steel crank
unique Miami engine balance specification
Crank shaft damper
twin-sheave pulley
supports
o 8pk supercharger drive system on rear sheave
o 6pk water pump and alternator drive on front sheave
unique frequency / damper tune
Con-rod
new high strength powder sintered forged con-rod to suit supercharged application
Piston, ring and pin
new generation light-weight high strength piston and ring pack
hard anodised top ring groove
floating pin design
nitrided steel piston pin
FEAD (Front end accessory drive)
2 drive systems
1 x 8pk belt which drives supercharger, power steering and AC compressor
1 x 6pk belt which drives water pump and alternator
Lubrication System
new cast aluminium high-volume winged oil pan
cast in baffles for oil control under heavy cornering, braking, acceleration
G-rotor style oil pump
full length composite windage tray
engine oil cooler
Ignition System
coil on plug
new iridium fine electrode tip spark plugs
Exhaust manifolds
new cast stainless steel high flow EU4 exhaust manifolds
optimised for cylinder flow balance and emissions performance
Supercharger inlet duct and eTB assy
new cast aluminium high-flow supercharger inlet duct
75mm electronic throttle body
Supercharger assembly
Harrop / Eaton designed HTV 1900 front drive, rear entry supercharger featuring:
o Eaton TVS 6th generation rotor set
o 1.9l per revolution displacement
o torsional decoupler in supercharger drive shaft for optimised NVH
o PCM controlled inlet bypass valve
o bypass operation for vacuum and boosted conditions
Intake manifold
new two-piece cast aluminium intake manifold
supercharger mounted under intake plenum as low as possible in engine vee providing:
o optimised weight distribution / lower centre of gravity
o optimised NVH
o optimised air path and runner tuning
o optimised engine performance
tuned length intake runners
features supercharger outlet air diffuser which
o controls air charge motion out of the supercharger
o delivers ideal cylinder to cylinder flow balance
POWERTRAIN SYSTEM TECHNICAL SPECIFICATIONS
Air intake system
new high-flow cold air intake system
new bonnet sealed open cold air box
high-flow conical filter
Exhaust system
high-flow thin foil technology metal matrix catalysts
twin-brick catalyst construction
140mm diameter, 2.1 litre per catalyst assembly
new cold end exhaust with FPV unique NVH tune
new quad outlet exhaust system
billet aluminium tail pipe finishers
new mufflers with new FPV tuning code
PCM controlled active exhaust system (Sedan only) to deliver
o Refinement and comfort for part throttle cruising applications
o Maximum V8 sound quality at idle and car manoeuvring
o Maximum V8 muscle car sound quality during spirited driving
Fuel system
new high-flow fuel pump
new two-piece stainless steel fuel rail assembly
4 Bar pressure return system
new high-flow fuel injectors
o increased flow range
o optimised targeting for EU4 emissions
Vehicle Cooling System
Brand new high-efficiency radiator and fan pack assembly
Twin variable speed fans
New high-efficiency automatic trans oil cooler system
New engine oil cooler and cooling system
Engine inlet thermostat control
New vehicle heater circuit
Automatic Transmission
Upgraded ZF 6HP26 transmission
new 7-plate clutch pack and 4-planet planetary gearset for improved torque capacity
Manual Transmission
Tremec TR6060 with new bell housing to suit new clutch system. Revised 2nd gear synchros for reduced shifting efforts
Clutch
ZF twin plate clutch common with Mustang GT500. New clutch release bearing common with Mustang GT500.
Engine Development Program:
Four levels of prototype:
Mule-level prototype – 5.4 litre XR8 engine fitted with supercharger and custom-fabricated manifolds. Used predominantly for cooling system development, calibration feasibility and performance and driveability target setting
A-level prototype – 5.0 litre Coyote Mustang prototype engines fitted with prototype manifolds, prototype pistons, prototype oil pan. Used predominantly for calibration development, emissions feasibility, vehicle testing.
B-level prototype - 5.0 litre Coyote Mustang prototype engines fitted with fully representative prototype manifolds, fully representative pistons, fully representative oil pan. Used predominantly for calibration finalisation and refinement, emissions testing and development, vehicle testing and attribute assessment.
Verification prototype – 5.0 litre Coyote Mustang Verification prototype engines fitted with off-tool unique Miami pistons, Air intake system, exhaust manifolds and lubrication system. Used predominantly for sign off certification and durability testing, and attribute sign off.
Edited by falcman
Considering the FPV F6 (turbo 6) is rated to 310kW by FPV but consistently measures above 280rwkw on our chassis dynos - which have a higher percentage loss than those in the US (~22%) - I would almost guarantee this is 335kW is closer to 360kW. This is without an intercooler and very little psi.
Also consider that this only spins to 6000rpm, so from that, also, you can see it's not only grossly under rated, but pegged back a fair bit in terms of rpms - the 1.9 litre unit can is good for a whole more psi at much more revs.
(Out of the box the F6 is good for 12.4-12.5 down the quarter. It weighs 4000lbs)
Barring all that, to have peak torque @ 2200rpm (all the way to 5500rpm) does a fair bit to the heart rate.
There's another reason Ford in Australia are hesitant to quote higher numbers: history has shown the media here will crucify Ford in particular when they've upped the ante. They (the media) caused the abortion of the Phase 4 GTHO, they also caused a stir when FPV released the original F6 with 550Nm of torque. There is a reason for FPV's comments from the first article below.
"We're not about the numbers on the back of the car ... I don't think we're in a space where we're going to be chasing what our competitors are doing," he notes. He also dismisses suggestions more power will encourage hoon behaviour, while linking the engine's "bloodlines" to the legendary GT-HO.
"I reject the notion that the people who buy these vehicles are irresponsible," he says. "If you look at some of the performance cars coming out of Europe, we are not out of step with the power figures or torque figures.''
FPV general manager Rod Barrett says potential owners are encouraged to learn how to drive their machines properly.
"Everybody who buys an FPV will get a drive day with John Bowe Driving," he says. "A lot of our owners are the type who check the weather forecast before taking their cars out of the garage, so that gives a good idea of how they value their cars.''
And another thing... the ZF auto was already rated to 600Nm prior to the changes and upgrades listed in the above post. One wonders why they had to do all that when they've quoted the torque to "570"Nm.
Edited by falcman
I was thinking either that, or a 7.0 L (427 ci) Boss? There was a 7.0 L rumored...
I think the 427 would be a bit overkill...a very limited run or 2000 or so would be nice, but I think the 351 would be a better overall engine in weight and performance in a Cobra, errr GT500 LOL
?....Moami for the Aussie version???? wouldnt Bondai Beach or something local have been more apt?
I agree...427 seems a bit much when a 351 would suffice. Of course, the GT500 isn't about sufficient! :hysterical:
600hp would be a good incremental jump over the current car's 550hp. And I agree, TT > Supercharger
V8 Twin Turbos?
perhaps when Ford gets some experience with packaging the V6 EB, they might revisit that topic,
the supercharged route was just easier to do......
Yeah, it doesn't look like the most space-efficient package.
I'm not up on packaging that much, so I ask... what would you recommend?
Just that at design stage, engineers can move the engine bay shape around and maximize space utilization when they have an idea where Ecoboost components need to sit. The current Falcon platform hasn't been designed to do that and I'd expect that we will see some brilliant engineering at play in the future. I'm comforted by the idea of really small V6 and V8 Ecoboost engines that give outstanding power and fuel economy, we're not there yeat but if gas prices turn nasty, I'm confident that RWd can access 400 hp with very few liters of capacity.
Performance never goes away, it just changes its delivery mode...
Edited by jpd80
