RichardJensen Posted May 14, 2008 Share Posted May 14, 2008 http://media.ford.com/article_display.cfm?article_id=28224 Duratec 25 is now the standard engine and Duratec 30 output is now 240hp, and gas mileage is estimated to be 1mpg higher for both 4 & 6 cylinder models. BTW, 240hp from a 3.0L engine is nothing to scoff at. Quote Link to comment Share on other sites More sharing options...
papilgee4evaeva Posted May 14, 2008 Share Posted May 14, 2008 http://media.ford.com/article_display.cfm?article_id=28224 Duratec 25 is now the standard engine and Duratec 30 output is now 240hp, and gas mileage is estimated to be 1mpg higher for both 4 & 6 cylinder models. BTW, 240hp from a 3.0L engine is nothing to scoff at. But watch the scoffing begin! This does bode well for the updated 3.0 for the Fusion. But why no power numbers for the D25? Quote Link to comment Share on other sites More sharing options...
svtenthusiast Posted May 14, 2008 Share Posted May 14, 2008 Are they getting rid of the rear drum brakes and going back to discs? The article mentions "Braking improvements focused on increasing initial braking response and further fine-tuning the vehicle’s anti-lock braking system" but doesn't note any hardware changes. Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted May 14, 2008 Share Posted May 14, 2008 All that extra power in the I4 and V-6 means 1.7 second quicker 0-60 times....pretty impressive Quote Link to comment Share on other sites More sharing options...
BORG Posted May 14, 2008 Share Posted May 14, 2008 Cool beans! Why didn't they mention the 6-spd? Quote Link to comment Share on other sites More sharing options...
Hugh Posted May 14, 2008 Share Posted May 14, 2008 I'd like to see more details on the powertrains and the braking system. Quote Link to comment Share on other sites More sharing options...
Hugh Posted May 14, 2008 Share Posted May 14, 2008 Cool beans! Why didn't they mention the 6-spd? I read an article on the media site all about the new 6A and where it's going. It's quite impressive. Quote Link to comment Share on other sites More sharing options...
Michael Reynolds Posted May 14, 2008 Share Posted May 14, 2008 I'd like to see more details on the powertrains and the braking system. That's what I'd like to see. I'm really curious to see if Ford has worked on the refinement issues of the D30. Having said that, it seems to me with the few tweaks the Escape should be received much better in the market place. Quote Link to comment Share on other sites More sharing options...
NickF1011 Posted May 14, 2008 Share Posted May 14, 2008 I'm really curious to see if Ford has worked on the refinement issues of the D30. Well, seems most of the complaints about the 3.0 are when it is revving at higher RPM. That's really the only time I would consider it a "thrashy" sounding engine in my expriences. With the 6-speed attached, it should keep the RPM considerably lower. Quote Link to comment Share on other sites More sharing options...
papilgee4evaeva Posted May 14, 2008 Share Posted May 14, 2008 Longer press release here. It mentions the transmissions as well. Quote Link to comment Share on other sites More sharing options...
sonofford Posted May 14, 2008 Share Posted May 14, 2008 There are two related articles as well, one about aerodynamic improvements, the other about low rolling-resistance tires (Michelin Latitudes). http://media.ford.com/article_display.cfm?article_id=28226 http://media.ford.com/article_display.cfm?article_id=28225 Quote Link to comment Share on other sites More sharing options...
Michael Reynolds Posted May 14, 2008 Share Posted May 14, 2008 Well, seems most of the complaints about the 3.0 are when it is revving at higher RPM. That's really the only time I would consider it a "thrashy" sounding engine in my expriences. With the 6-speed attached, it should keep the RPM considerably lower. It starts to get slightly noisy during mid-range as well. You can hear it, but there isn't much in terms of vibration inside of the cabin. My guess is a little bit more sound deadening might go a long way. Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted May 14, 2008 Share Posted May 14, 2008 The new 2.5 I4 puts out 171 hp/171 torque....very decent numbers and should zoot around the 09 Fusion very well Quote Link to comment Share on other sites More sharing options...
RichardJensen Posted May 14, 2008 Author Share Posted May 14, 2008 Oh cool! It's got a built in power inverter and a 110V AC outlet! Quote Link to comment Share on other sites More sharing options...
351cid Posted May 14, 2008 Share Posted May 14, 2008 It starts to get slightly noisy during mid-range as well. You can hear it, but there isn't much in terms of vibration inside of the cabin. My guess is a little bit more sound deadening might go a long way. I've never understood the harshness complaint of the 3.0L Duratec. I've owned two of them...one in a 2001 Taurus and the other in my wife's Five Hundred. Maybe it's because I enjoy the harmony of an engine's sounds...I dunno. For comparison...the 3.3L (?) that was in my father in-law's Toyota was no better or worse in sounds. He had two different engines in that car (sludge), so it wasn't just a one off. Quote Link to comment Share on other sites More sharing options...
Michael Reynolds Posted May 14, 2008 Share Posted May 14, 2008 I've never understood the harshness complaint of the 3.0L Duratec. I've owned two of them...one in a 2001 Taurus and the other in my wife's Five Hundred. Maybe it's because I enjoy the harmony of an engine's sounds...I dunno. For comparison...the 3.3L (?) that was in my father in-law's Toyota was no better or worse in sounds. He had two different engines in that car (sludge), so it wasn't just a one off. I'm not implying it's a bad engine, it just gets a bit noisy. It became even more evident after driving it and another car back to back on a reg. basis. Quote Link to comment Share on other sites More sharing options...
351cid Posted May 14, 2008 Share Posted May 14, 2008 I'm not implying it's a bad engine, it just gets a bit noisy. It became even more evident after driving it and another car back to back on a reg. basis. reckon that's because of the timing chains? Quote Link to comment Share on other sites More sharing options...
NickF1011 Posted May 14, 2008 Share Posted May 14, 2008 Oh cool! It's got a built in power inverter and a 110V AC outlet! I've never much found the need for an AC outlet in my car, but I imagine the road warriors with laptops etc would find it handy. I'm rather surprised how few models offer it. It's not exactly rocket science or cost prohibitive to put one in. Quote Link to comment Share on other sites More sharing options...
Michael Reynolds Posted May 14, 2008 Share Posted May 14, 2008 reckon that's because of the timing chains? Nope, can't put my finger on it but I don't think that's what it is. Quote Link to comment Share on other sites More sharing options...
RichardJensen Posted May 14, 2008 Author Share Posted May 14, 2008 I've never much found the need for an AC outlet in my car, but I imagine the road warriors with laptops etc would find it handy. I'm rather surprised how few models offer it. It's not exactly rocket science or cost prohibitive to put one in. My inverter gets stuffed in the center console when not in use. I was really impressed when I saw one of those things in a Toyota Matrix. And yeah, it's real handy for charging laptop batteries on the road. I would imagine it's also useful for campers... Quote Link to comment Share on other sites More sharing options...
soupy Posted May 14, 2008 Share Posted May 14, 2008 http://media.ford.com/article_display.cfm?article_id=28224 Duratec 25 is now the standard engine and Duratec 30 output is now 240hp, and gas mileage is estimated to be 1mpg higher for both 4 & 6 cylinder models. BTW, 240hp from a 3.0L engine is nothing to scoff at. Looked at a 95' Mustang GT for sale just last weekend. 225 HP! Quote Link to comment Share on other sites More sharing options...
Joe771476 Posted May 14, 2008 Share Posted May 14, 2008 In between pitching Mariners, Mercury spokeswoman Jill appeared on an episode of "Monk." Quote Link to comment Share on other sites More sharing options...
Extreme4x4 Posted May 14, 2008 Share Posted May 14, 2008 I love the 3.0 in my '03 Tribute. I don't really like silent vehicles, and the 3.0 puts out a good growl when you really get on it. Why it gets such a bad rap, I don't know. One couldn't ask for better reliability out of an engine.............. and they really wake up once you get 10-20K miles on them. 64K completely trouble free miles here. The only thing I don't like about my Tribute is the trans. The 3.0 deserves much better. Quote Link to comment Share on other sites More sharing options...
kyle Posted May 14, 2008 Share Posted May 14, 2008 My inverter gets stuffed in the center console when not in use. I was really impressed when I saw one of those things in a Toyota Matrix. And yeah, it's real handy for charging laptop batteries on the road. I would imagine it's also useful for campers... Yah I was glad they added that feature. Think it was standard in the hybird in 08. Between my blackberry, blue tooth and garmin I need chargers. Quote Link to comment Share on other sites More sharing options...
Hugh Posted May 14, 2008 Share Posted May 14, 2008 (edited) All those improvements will go a long way to generate sales. I drove my friends Escape and the 3.0 was been held back by the 4A. That was a point why I never got one although I liked the overall package. When the 08 came out, I liked the improvements but I could have picked up a 07 at a better price. I drove my fathers Five Hundred demo with the 3.0 and a 6A and I thought that was great. Now with the 09, that'll convince me to come back to the dealership. Edited May 14, 2008 by Hugh Quote Link to comment Share on other sites More sharing options...
