PolarisCobra
How many miles on your 3.5 Ecoboost?
Just curious to get an idea of how long these can run.
How many miles on yours?
What year is it?
Have you had any major problems?
My nephews 2011 F150 has 180k on it.  The spark plugs were replaced at 60K and he just replaced water pump b/c it had a small leak.  He also has an Explorer Sport with 100k and no issues.  My brother-in-laws have had a number of F150s with 3.5s that have gone over 100,000 with no issues. Any 3.5 I have had have been good however I don’t keep them Long enough to hit those mileage numbers.
I've got 57k on my 18 I just had the cam phasers replaced last week
Mitch
I have a 2016 King Ranch with 26,000 miles. Bought it brand new
Never had an issue with any of my Ecoboosts.  My opinion very solid motor that Ford has built and worked out all bugs.
I have a 2013 F150 Lariat that has 137,000 on it and have had very few issues on it.  I just replaced the water pump and had to have the throttle body flashed to reset it as the truck went into limp mode off and on and that happened last year.  Based on the manual I've had things serviced per the schedule and replaced the spark plugs at 100k.
2011 3.5L owned since new. 215,000 miles.  Just hit 10 years recently. Did a timing chain at 89,000 m and now 2nd one at 214,000. Did water pump and one turbo with 1st TC. Water pump again a month ago. I think they did one other turbo in between. Never had the fuel in crank case issue. Time for new truck. Next either 7.3L SD or rumored 6.8L in F150.
I've got a 2011 with 125000. I've had all the seals done-  120000,  water pump and timing chains done at the same time...
~190k now on my 2011 ecoboost 3.5 fx4. No significant engine related issues that I can recall. Hope I'm in a 21 Poweboost here sooner than later.
Posted (edited)
2014 3.5L EB FX4 with 60k miles.  Changed plugs at 50k no issues to date.
Edited by Evolrider
2013 FX4 Screw with 3.5 EB.  111k miles.  Had coolant leak from driver's side turbo at 80k miles ($5 part, buddy charged me $150 to fix); has been solid otherwise.
G
2012 Platinum 108K miles, 25k+ towing.  Had a turbo coolant o ring start to leak, lower fuel pressure pump replaced, and scheduled maintenance performed.
2014 XLT, SCAB, 8' Box w/ HDPP & Max Tow = 97,000
I've got a 2018 xlt 3.5 crew cab with the 6.5' bed.  Currently at 73,000.  No issues to date with the motor.  It spends the summers towing a 28' 5th wheel and the winters towing a 25' enclosed snowmobile trailer.
It will be 3 years in Oct.  I drive alot for work.  They provide me with a gas card and pay 40 cents a mile
I have a 2017 with 47k on it. I put 5k on it in the last two weeks n a trip out west. I guess I don't drive it enough. I was bummed that I had to put a starter in it last fall. Other than that no issues.
2018 F-150 with 57K on the odometer. I use it to tow a boat (~7500#-8000#). Haven't had a single issue out of it, runs just as good as the day it was new.
78k. Just got it back after 3 months of being in the shop for a transmission, drivers side turbo replacement and cam phasers. First time in the shop since buying it in 17.
2017 F-150 Raptor.  83,000 miles.  Cam phasers replaced at 55,000 miles, otherwise no issues.
2011 F-150 that I got used with 80k miles 4 years ago. I've put another 75k miles on it since then with no problems (knock on wood), just typical maintenance on it has been all
Ive got 67K on mine and just heard the cam Phasers for the first time last week.  going in the shop next week.
Good thread. Considering placing an order for a 2022 F150 Tremor w/Torsen front diff. I'd assume the 22 3.5 ecoboost should be rock solid. I know cam phasers have been a big issue with the 3.5 ecoboost. Ford Boss Me on YouTube says the 5.0 coyote is more likely to have less issues long term, but 5.0 is not available on the 22 F150 Tremor
I have a 2015 f150 lariat.  Only sitting at 85,000 miles but runs great stil.  Only thing done is scheduled maintenance.   To sure if going to keep or trade in on new 350.  Wife wants me to keep it for her over the Lincoln..
