V10 swapped RWD converted modern Lincoln Continental
I've been following them, pretty interesting what they are doing, honestly with as many changes they have made, its more like "why  not just start on a different platform instead" (Maybe Explorer based since they went with the RWD route), but they are pretty passionate about it.
It would have been easier, but a V10 explorer would have been arguably less cool than a sedan.
2 hours ago, akirby said:
He meant put the continental body on an Explorer chassis
Out of curiosity, because the Continental is a unibody, and the cd6 explorer is a unibody, how would you go about doing that? Or if you wanted to take the frame of an older body on frame explorer and slot that under a modern Continental body.
I was under the impression that with unibody cars, because the chassis and frame were essentially this combined unit, that you couldn't put the body of a modern car on another chassis like you could back in the day when everything was body on frame where it was a lot easier to pull a frame and a body apart.
But if it is possible to do that, that would be quite cool, I didn't even know that was an option. The more you know.
Not as easy as body on frame, but the same way they built fusion and edge on the same platform.  Or escape and focus.  Fiesta and Ecosport.  Explorer and Taurus.
Same guys tested an old Ford V10 Super Duty without balance shaft (rotating) to prove it won’t “blow up”.  Never heard that myth so not sure how widespread it is.  Apparently some don’t understand what balance shafts do.  Obviously their 4-valve V10 does not have one.  Wonder if original Ford V10 prototypes with 4-valve heads also deleted the balance shaft?
