Stray Kat Posted January 2, 2010 Share Posted January 2, 2010 (edited) Anyone care to speculate or to inform us as to why the 6.7 has the SAE? bellhousing bolt pattern on the bell flange? Or at least it looks to me like it does. Will this beast see duty in bigger trucks like the big Mediums ? Or maybe it can be utilized as a marine engine. Seems like Ford has plans for this engine. What do you think? Edited January 2, 2010 by Stray Kat Quote Link to comment Share on other sites More sharing options...
RichardJensen Posted January 2, 2010 Share Posted January 2, 2010 Ford may also intend to use the 6R140 in the medium duty market. Quote Link to comment Share on other sites More sharing options...
theoldwizard Posted January 2, 2010 Share Posted January 2, 2010 This would make one heck of a nice boat engine for a single screw cruiser up to about 35'. The aluminum heads would require a closed cooling system with heat exchanger so packaging would be an issue. Most other "non transportation" applications don't need this much power, or they already have engines that are all cast iron and have a proven durability record of millions of hours of operations. Quote Link to comment Share on other sites More sharing options...
Stray Kat Posted January 2, 2010 Author Share Posted January 2, 2010 I would love it if Ford revitalized their Power Products division and became an engine vendor again. In my experience that was the absolute cheapest way to purchase new Ford engines. There are a few early Ford vehicles around these parts, running with those old 302 and 351 "Marine Boss" to prove it. I think the point about the fresh water exchanger is well taken but I do believe those are used more often than not in the salt water. If you love your engine it's crazy not to run one cast iron or not. There may be a huge market for th 6.7 since the big block Chevy is no longer in production. I read that Mercury Marine has to hand assemble those things from component parts now to keep their big inch powerplant business going. That sounds expensive. Is there a shot Ford could take that business back? This lightweight, compact diesel would be a killer choice all things considered. Quote Link to comment Share on other sites More sharing options...
200MPHCOBRA Posted January 2, 2010 Share Posted January 2, 2010 The sport boat market has been dabbling with diesels recently. The ones I have seen used the chevy diesel and made it to about 70mph, with far superior fuel usage as compared to it gas counterpart. One problem is rpm range, 100 mph is the entry point of what is considered a "hot boat" but I can see a time when a transmission equipped diesel powered sport boat could hold its own and then some against the gas burners. As for the closed cooling, it is becoming much more common in the hi perf segment, as many are fuel injected and almost all have aluminum intakes/heads. For instance Ilmor makes a hell of a compact marinized dodge viper v10 engine. http://www.ilmor.com/marine/marine-engines.html Quote Link to comment Share on other sites More sharing options...
White99GT Posted January 2, 2010 Share Posted January 2, 2010 (edited) This engine should should eliminate the headgasket problems of the 6.0 family with 6 head bolts per cylinder. The 6.7 is going to be a beast. Edited January 2, 2010 by White99GT Quote Link to comment Share on other sites More sharing options...
atvman Posted January 2, 2010 Share Posted January 2, 2010 This engine should should eliminate the headgasket problems of the 6.0 family with 6 head bolts per cylinder. The 6.7 is going to be a beast. I'm an engineer, so new tech is highly interesting to me. I've been reading up on a lot of the newer Ford engines and transmissions, and I really like what I see with the 6.7L and the new SD trans. It appears Ford is very serious about this combo. Ford bencharked the Allison trans in GM HD trucks, which is a good thing. Ford claims their new transmission is both more durable and ligher than the Allison trans. Ford also benchmarked the 6.0L PSD, the 6.4L PSD, and the GM Duramax diesel engines in the design of the engine. The 6.0L was problematic, but so far the 6.4L seems reliable and the Duramax is quite proven. I have every reason to believe this new 6.7L will be at least as reliable as the 6.4L and Duramax. Also, the CGI block and reverse heads are both very promising. There is one thing I question though, why did they go with Al heads? I understand they are lighter than CGI heads would have been, but does the driver of an 8,000lb truck towing a 15,000lb trailer really care about a hundred pounds or so of weight savings? Now, if Ford wants to build a scaled down Scorpion for half tons in a few years, then lighter heads make a lot of sense. Otherwise, the strength and heat characteristics of CGI would have probably been a better choice. Overall, I like what I see and I think Ford will have a lot of success here. Quote Link to comment Share on other sites More sharing options...
White99GT Posted January 2, 2010 Share Posted January 2, 2010 Lighter block, lighter heads, and less plumbing should lead to the 6.7 being substantially lighter than the 6.0/6.4. Not a bad thing, aluminum heads haven't proven to be a problem with the Duramax or the European diesels. While iron heads may give some piece of mind, I think we'll find that aluminum heads on the 6.7 will only be a boon, especially with 6 bolts per cylinder. Quote Link to comment Share on other sites More sharing options...
fbmphil Posted January 2, 2010 Share Posted January 2, 2010 Aluminum heads are easier to machine. Quote Link to comment Share on other sites More sharing options...
atvman Posted January 2, 2010 Share Posted January 2, 2010 Aluminum heads are easier to machine. Not necessarily. The graphite in CGI will act as a built in lubricant while machining, allowing extended tool life. Quote Link to comment Share on other sites More sharing options...
jpd80 Posted January 2, 2010 Share Posted January 2, 2010 (edited) Not necessarily. The graphite in CGI will act as a built in lubricant while machining, allowing extended tool life. A little knowledge can be dangerous, CGI is difficult to machine. Sulphur is the lubricant in cast Irons but it's not present in CGI. Here's a link CGI has graphite that resembles coral; the form of the graphite structures, as is the case with nodular iron, is fundamentally controlled by the amount of magnesium in the mix. The microstructure of the CGI material is such that there aren’t the stress risers and fault lines associated with gray iron, nor are there the thermal requirements characteristic of machining nodular iron. So because CGI is in the middle of the easy-to-machine and the highly abrasive, one might appropriately imagine that machining should be a fairly straightforward thing. Improving All Aspects. Not so. Roger Cope, Lamb Technicon’s vice president of Business Development, observes, “Many people think that they can just slow their machines down and machine CGI. But it destroys inserts.” For one thing, unlike gray iron, CGI is a very low sulfur iron. What sulfur does in an iron is form, in effect, a lubricating layer (of manganese sulfide) that facilitates machining. CGI doesn’t have it. Cope cites studies that indicate that compared with machining gray iron, tool life for milling and drilling operations in CGI are half and tool life in CGI boring operations is just one-tenth. So there are lots of considerations related to setting up the machine, the tooling, and the fixturing to handle cutting. For one thing, the machine tool power requirements for CGI are higher—on the order of from 10 to 30%. Appropriate machinery for handling CGI is equipped with large spindle motors, stiff spindles, and rigid fixturing. So it is not just a matter of lowering the speed and increasing the speed. And there is also the need to get production rates higher, so it is necessary to have optimized parameters. Tomlinson notes that no one can simply expect to take an existing block line and then running CGI castings down it. “You have to consider all aspects of the line,” he says. Among the specific recommendations are to have larger spindle motors; higher torque spindle drives; larger spindles; increased feed unit and feed drive stiffness and load capability; stiffer tool holding; increased damping; and finite element analysis of fixtures. Roughing machines must certainly be setup to take the rigors of machining CGI, otherwise, production is likely to be down rather quickly. All that said, however, CGI still looks promising for diesels. Not only is there a projected increase in the use of the material for blocks, but cylinder heads will also be moving to the material. Edited January 2, 2010 by jpd80 Quote Link to comment Share on other sites More sharing options...
theoldwizard Posted January 2, 2010 Share Posted January 2, 2010 (edited) In addition to what jpd80 said, there are only a couple of companies that make production tooling for machining CGI. I suspect that some of the compound curves in the heads might not be achievable in CGI. Additionally CGI, costs a lot more than plain iron. The heads likely do not require the strength of either CGI or iron. Add it, up the weight saved in the AL head and the easy of machining are probably the reason why the material is used. Oh yeah, AL is easily recycled. Edited January 2, 2010 by theoldwizard Quote Link to comment Share on other sites More sharing options...
RichardJensen Posted January 3, 2010 Share Posted January 3, 2010 And it's cheaper. Quote Link to comment Share on other sites More sharing options...
Bob Rosadini Posted January 3, 2010 Share Posted January 3, 2010 Back to the original issue, with the HP and torque numbers this engine puts out, it certainly should be safe for use in the 650 (max GVW 26,000) and even the 750 (33,000 /37,000). Forty years ago, a "big bore" diesel used in a class 8 often didn't have the HP and torque numbers this thing has. As for the transmission, time will tell. One thing is for sure, Ford can't afford to lay an egg with this engine or the transmission after the last PowerStroke disaster. One thing to be concerned about is misapplication- often times when new engines came out with impressive torque /HP numbers, they were put in situations they should not have been in. Let's hope that is not the case here Quote Link to comment Share on other sites More sharing options...
Moosetang Posted January 3, 2010 Share Posted January 3, 2010 (edited) I'm wondering if someone at Ford is thinking possible military sales with Scorpion. While its being built in Mexico could be problematic for US Military sales (if someone bitches), its got power and efficiency for M-ATV style vehicles for other countries (Plasan Sand Cat 2?) or even Humvee-replacements. Edited January 3, 2010 by Moosetang Quote Link to comment Share on other sites More sharing options...
theoldwizard Posted January 3, 2010 Share Posted January 3, 2010 I'm wondering if someone at Ford is thinking possible military sales with Scorpion. Possibly. But Navistar just got a huge contract with the Army so it will be several years before there is a chance of Ford getting in their foot in the door. Quote Link to comment Share on other sites More sharing options...
Moosetang Posted January 3, 2010 Share Posted January 3, 2010 Possibly. But Navistar just got a huge contract with the Army so it will be several years before there is a chance of Ford getting in their foot in the door. I disagree. There's alot of uncertainty after the M-ATV in the light/medium vehicle arena and most of the competitors for contracts these days are based on teams. Ford could hop on a team fairly easily if Scorpion is more appealing than their current engine choices. That said, the foreign/export sales could still be enticing in the nearer-term even if they're out of US DoD programs for the near future. Quote Link to comment Share on other sites More sharing options...
jpd80 Posted January 3, 2010 Share Posted January 3, 2010 (edited) How common is the SAE bolt flange, could it help Ford gain sales from buyers repowering older equipment? Making multiple suppliers use a common flange would surely help end users get better deals too... Edited January 3, 2010 by jpd80 Quote Link to comment Share on other sites More sharing options...
7Mary3 Posted January 3, 2010 Share Posted January 3, 2010 I am sure Ford would like to sell the 6.7L to other OEM's at this point, because from what I understand there is little likelyhood it will meet the sales targets Ford planed for during the 6.7L's development. This isn't because of the engine itself, it is due to the collapse of the 'personal' light truck market and the shift away from diesel, due in a large part to substantially increased fuel and diesel engine purchase prices. That however might be a difficult objective even if the 6.7L is a stellar engine. The medium and heavy commercial truck market is becoming vertically integrated, and no more are you seeing a wide selection of vendor supplied diesels offered in these vehicles. More and more, each manufacturer is either emphasising proprietary (in-house) engines or in closely aligning with only one engine supplier. For instance, the Daimler Truck N.A. Companies are using their own Mercedes and Detroit Diesel engines, Navistar is using their own medium duty diesels along with proprietary M.A.N. and Caterpillar engines, Volvo and Mack are of course using Volvo, and PACCAR is going with Cummins exclusively. I would imagine Ford will want to see the 6.7L in the 650 and 750, but from what I hear it will be International's decision whether to offer it or not. My question is what bell housing bolt pattern will the 6.2L 'Boss' engine have? I think Ford might have a better shot at selling that engine to other OEM's than the 6.7L diesel, particularly it gaseous fueled versions are available. Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted January 3, 2010 Share Posted January 3, 2010 My question is what bell housing bolt pattern will the 6.2L 'Boss' engine have? I think Ford might have a better shot at selling that engine to other OEM's than the 6.7L diesel, particularly it gaseous fueled versions are available. From my understanding, the 6.2L boss will be also being using the same Powershift transmission that is mounted to the 6.7L diesel in Super Duty applications, not sure about top end F-150s though Quote Link to comment Share on other sites More sharing options...
theoldwizard Posted January 3, 2010 Share Posted January 3, 2010 This isn't because of the engine itself, it is due to the collapse of the 'personal' light truck market and the shift away from diesel, due in a large part to substantially increased fuel and diesel engine purchase prices. I agree 100%. Diesel engine prices in light duty trucks are going to continue to go up as additional emission control are required. However, I still believe there is some "funny business" going on with the price of diesel fuel in the US. There is no "logical" reason for it to cost more than gasoline. Quote Link to comment Share on other sites More sharing options...
lfeg Posted January 4, 2010 Share Posted January 4, 2010 Using an SAE flywheel housing is a smart move, and a potential cost saver. In the commercial world SAE flanges and flywheels are the defacto standard. For commercial and industrial service transmissions and engines you want to have mountings to the standard so you have the widest possible range of transmission / engine fit up available. Just look at the F650 and F750 (if they continue on). The pickups and F450/F550 equipped with the 6.7 will only be available with the automatic. In the heavier mediums the market demands manuals. The purpose designed manuals are made to fit SAE. No costly specials or adaptations will be needed. Quote Link to comment Share on other sites More sharing options...
atvman Posted January 4, 2010 Share Posted January 4, 2010 Using an SAE flywheel housing is a smart move, and a potential cost saver. In the commercial world SAE flanges and flywheels are the defacto standard. For commercial and industrial service transmissions and engines you want to have mountings to the standard so you have the widest possible range of transmission / engine fit up available. Just look at the F650 and F750 (if they continue on). The pickups and F450/F550 equipped with the 6.7 will only be available with the automatic. In the heavier mediums the market demands manuals. The purpose designed manuals are made to fit SAE. No costly specials or adaptations will be needed. It also opens up the possibility of swapping a medium duty trans into the F450. Who knows, maybe Ford is working on that already. Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted January 5, 2010 Share Posted January 5, 2010 However, I still believe there is some "funny business" going on with the price of diesel fuel in the US. There is no "logical" reason for it to cost more than gasoline. Aren't you forgetting about all that new tooling/etc needed to make low-sulfur Diesel fuel that just started a year or two ago? The whole Petroleum pricing thing (both gas and Diesel) is "funny Business"...I never seen an industry where prices can go up .10 cents a gallon in 24 hours or more of the course of a couple days because product of it goes up a couple dollars. Any other industry it takes weeks/months for the supplier to pass on price increases due to raw material prices going up! Quote Link to comment Share on other sites More sharing options...
theoldwizard Posted January 5, 2010 Share Posted January 5, 2010 Aren't you forgetting about all that new tooling/etc needed to make low-sulfur Diesel fuel that just started a year or two ago? I am well aware of this. Did you know that about the same time that ULSD became the law of the land in the US, EXPORT of Low Sulfur Diesel (LSD) from the US to countries that still allowed it, shot through the roof ! Neat trick. By NOT installing the necessary equipment to make ULSD, refineries created a shortage in the US while undercutting other refineries on the global market and still making a good profit. This was a couple of years ago. I would have expected that with the addition of some new major refineries in India and China during 2009, that there would no longer be a shortage of LSD on the global market. This situation along with the current price of oil (back over $80/barrel) can't last. With demand for finished petroleum product still low, and most oil storage facilities filled and non-OPEC (lead by Russia) oil countries not willing to cut production, the whole house of cards is going to collapse, sooner rather than later. When the price of a gallon of diesel gets back to where it belongs (less than the price of a gallon of gasoline) I hope Ford can quickly install diesels in much of their product line. Quote Link to comment Share on other sites More sharing options...
