coupe3w Posted August 11, 2021 Share Posted August 11, 2021 7 minutes ago, 5.2 VooDoo said: Ford's TSB write up...not mine... Was just asking as a general question. Quote Link to comment Share on other sites More sharing options...
5.2 VooDoo Posted August 11, 2021 Share Posted August 11, 2021 Understood... I have a GT 350...the engine sounds normal to me as it has since day one. However if you wanted to make an argument that it sounds like a "typewriter" you very well could...to my ear its the fuel injectors responsible for the noise. Quote Link to comment Share on other sites More sharing options...
KeyLime Posted August 12, 2021 Share Posted August 12, 2021 Let's really go down the rabbit hole and talk about the infamous 2k rattle. Quote Link to comment Share on other sites More sharing options...
coupe3w Posted August 12, 2021 Share Posted August 12, 2021 19 hours ago, 5.2 VooDoo said: Understood... I have a GT 350...the engine sounds normal to me as it has since day one. However if you wanted to make an argument that it sounds like a "typewriter" you very well could...to my ear its the fuel injectors responsible for the noise. But it seams to happen after an oil change. So I doubt it has anything to do with the injectors. Quote Link to comment Share on other sites More sharing options...
ryant601 Posted December 2, 2021 Share Posted December 2, 2021 Ceratec if it really bothers you, and call it a day. My '16 GT had the tick basically from the first oil change until I sold it this past summer. That said, I have a F-150 5.0 on order and fully expect it to tick too. It's really a badge of honor in my opinion, I understand folks want their $50k car to sound smooth and quiet...but they're just not. Quote Link to comment Share on other sites More sharing options...
traxiii Posted December 9, 2021 Share Posted December 9, 2021 I've also heard the sound described as Barbecue Tick, like the sound your grill makes when you turn off the gas and the metal is cooling off. Quote Link to comment Share on other sites More sharing options...
Kevin Berry Posted November 15, 2024 Share Posted November 15, 2024 2022 Mustang GT Premium 401 A...Just had an oil change done and this is the INFAMOUS type writer ticking sound that FORD says is normal !!!! If this normal what is causing this sound and what is making this sound ?? Quote Link to comment Share on other sites More sharing options...
coupe3w Posted November 17, 2024 Share Posted November 17, 2024 On 11/15/2024 at 1:52 PM, Kevin Berry said: 2022 Mustang GT Premium 401 A...Just had an oil change done and this is the INFAMOUS type writer ticking sound that FORD says is normal !!!! If this normal what is causing this sound and what is making this sound ?? Nobody really knows what causes it. i have a 21 Mach1 and I have no ticking. I change my own oil and use Motorcraft 5W-30 synthetic blend oil and filters. They say it doesn't cause any harm but it is annoying my friends F150 does it. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 17, 2024 Share Posted November 17, 2024 On 11/15/2024 at 1:52 PM, Kevin Berry said: 2022 Mustang GT Premium 401 A...Just had an oil change done and this is the INFAMOUS type writer ticking sound that FORD says is normal !!!! If this normal what is causing this sound and what is making this sound ?? It’s the direct injection causing the ticking noise. They all do it. Quote Link to comment Share on other sites More sharing options...
coupe3w Posted November 17, 2024 Share Posted November 17, 2024 14 minutes ago, akirby said: It’s the direct injection causing the ticking noise. They all do it. No it's not. The noise comes from down low in the crankcase area. Quote Link to comment Share on other sites More sharing options...
brucelinc Posted November 17, 2024 Share Posted November 17, 2024 All injectors tick but some 5.0s have an additional tick besides the injectors. There is a lot of controversy on the cause but it usually presents itself after an oil change. My Mustang never had that tick but I was in a Mustang club and several members definitely had it. Ford says it is not harmful to the engine and calls it normal. Adding Ceratec to the oil has been known to stop it. I have witnessed that myself but do not have an explanation for how or why it works. Quote Link to comment Share on other sites More sharing options...
coupe3w Posted November 17, 2024 Share Posted November 17, 2024 7 minutes ago, brucelinc said: All injectors tick but some 5.0s have an additional tick besides the injectors. There is a lot of controversy on the cause but it usually presents itself after an oil change. My Mustang never had that tick but I was in a Mustang club and several members definitely had it. Ford says it is not harmful to the engine and calls it normal. Adding Ceratec to the oil has been known to stop it. I have witnessed that myself but do not have an explanation for how or why it works. Have heard this also. Ford does not recommend oil additives. It may void your engine warranty. Quote Link to comment Share on other sites More sharing options...
tbone Posted November 18, 2024 Share Posted November 18, 2024 On 11/17/2024 at 12:06 PM, coupe3w said: Have heard this also. Ford does not recommend oil additives. It may void your engine warranty. Then perhaps they should figure out a real solution, because it’s annoying as hell and sounds like your engine is going south. I had an F150 that my son drove that had it and it was a major irrigation for me. It also makes people ask what’s wrong with your truck. I took it to a dealer and they said the motor needed replaced, but we continued to drive it for several thousand miles without it blowing up. So was it a shady dealer or is it normal? What the tick does not do is instill confidence in your vehicle. Quote Link to comment Share on other sites More sharing options...
coupe3w Posted November 18, 2024 Share Posted November 18, 2024 30 minutes ago, tbone said: What the tick does not do is instill confidence in your vehicle. I agree 100% 1 Quote Link to comment Share on other sites More sharing options...
blksn8k2 Posted April 3, 2025 Share Posted April 3, 2025 I've also seen youtube videos that claim some of the noise comes from the VCT (Variable Cam Timing) solenoid which is located in the driver side valve cover. Interestingly, on my '23 F-150 Tremor with the 5.0L there is a foam cover on top of that valve cover only (separate from the foam covers on the injectors) and that engine is worlds quieter than the one in my previous '18 F-150. It's also the Gen 4 Coyote vs the Gen 3 and I'm sure there are other more significant differences including cylinder deactivation. When I was looking at '23 F-150s a dealer salesman told me that Ford had issues with noisy 5.0Ls in '18 and '19 F-150s but that was probably just BS in hopes that I would take less for my '18 on a trade. Quote Link to comment Share on other sites More sharing options...
