Correct and that is probably appealing to GM’s HD buyers, less stressed and more headroom for future increases.
By Sherminator98 · Posted
From what I can see, the Slate is using a 65 kwh battery and only getting 205 miles Assuming the Fathom is about 15% more efficient, that would give it the range of about 235 miles using the same battery size, though i've seen reports that it might use a slightly smaller battery size (roughly 50 kwh) adding 20 kwh to that would give it another 50-70 miles. Maybe the fathom is using a smaller battery to get the same range and the larger battery will only be slightly larger than 65 kwh to get more range -
By blazerdude20 · Posted
Potentially. There is a bit of back and forth on this topic in the article linked here. It’s only 7-8 months old but who knows how much deflection the engineers were giving in their responses. https://www.thedrive.com/news/are-diesel-truck-engines-about-to-get-even-bigger-we-asked-the-experts -
Could be either. The From the Road guides have multiple dates, giving credence to the theory that there are updates to only parts of the guide such as individual pages, but I haven't seen any in that format before 2024, so it may have been a complete standalone update. I have not seen it in any other resources or archives, so I will go through my copies of any 2020 guides posted after 8/1/19 to see if that section has the update or not. I don't have any other insight as of now. I'm also looking for other versions for anything older than 2016 when this archive started, besides the versions we have here.
I came across this PDF, and the last page is dated 08/01/19 and specifically identifies itself as the 2020 F-150 Color & Trim Availability page. This is what led me to believe there may have been an 08/01/19 update to the 2020 F-150 Order Guide. I don't have a master list of updates, though. I'm just trying to find out whether a complete 08/01/19 version of the 2020 F-150 Order Guide was ever released, or if this page was simply a separate update to the original 07/15/19 guide. Does this help clarify what I'm looking for? 6133 OF ATTACH E ANDERSON AUTO GROUP.pdf
But GMs new 8.3L only has 550 hp and 1230 lb/ft. The Ford HO 6.7 is 500/1200. Virtually identical on paper.
GM have a +8 lire Duramax coming out so the new Powerstroke is clearly to stop GM getting to far out in front. Might also be a big plus for the Medium Duty too.
Some nice shots of Ford C-series including the C-series-based Mack built by Thibault in Canada at around 12:00 mark. (401) 8 Forgotten Fire Truck Brands That Vanished From 1930s To 1970s - YouTube
28-32 depending on terrain and speeds.
Exactly, you nailed it and even VW had issues with a very similar dry clutch gearbox. Product development engineer Tom Langeland reported that the DPS6 PowerShift dry-clutch gearbox suffered from "nasty launch judder"—intense vibration starting from a stop—that failed to clear up even after driving many miles. In an August 31, 2010 email sent six months before the 2012 Ford Focus reached the market, he warned colleagues and supervisors that engineers could not achieve a driveable calibration for production and stated that "the clutch torque delivery MUST BE IMPROVED". According to investigative reporting on internal documents, engineers also warned that the dry-clutch design lacked adequate cooling and was not ready for production, yet Ford proceeded with the launch anyway. You can read more in this WhichCar report on PowerShift pre-production warnings and this Chicago Tribune report on Ford engineers' accounts. https://www.whichcar.com.au/news/ford-knew-powershift-automatic-faulty
