Blue Oval Forums
Escapism
Porosity in Ford Blocks
So what’s going on with all the TSB’s about replacing long blocks. The very active Fordescape.org forum that I participate in has quite a few folks getting long blocks replaced due to coolant intrusion in the cylinders. Both 1.5 and 2.0’s has TSBs released.
Not really sure if the engine ID tag would do any good  Is the casting done at a different location than the engine assembly?
I traded in my 2013 for a 2017 Ti 2.0  Love my vehicle, but now I’m nervous
Just thought I would try to get some honest answers here.
Haven't heard anything about that. I have a 2.0 in my 17 Fusion. No engine issues with almost 40k.
Interesting! It’s the first I’ve heard of it. So far I’ve done 2 UOA’s, no presence of coolant. No white smoke. No issues. Maybe I’ll do another UOA before 50k just to be certain.
My parents 2013 Ti and my Wife's 2017 SE with the 2L Ecoboost have been fine so far
Porosity is NOT the issue. Core shift due to the stress relief cuts between the cylinders are. The cuts make it so the fire ring cannot seal properly if there is even a little shift. The new short blocks have cross drilled reliefs rather than cut. Not sure when production moved to these.
As of now, the 1.5 is being repaired with short blocks unless the plugs bind in the holes from the coolant. They don't even want tear down on those now. The 2.0 and 1.6 are long block for intrusion only.  FYI: 1.6 has always been 6006 since launch.
Edited by YT90SC
Thanks for the reply. Sounds like it is totally random. Are the block final machining done at the assembly plant? And what is "6006" mean?
Edited by Escapism
And then there's this:
If by assembly plant you mean the engine plant then yes. Engines are delivered to final assembly completely built minus whatever unique wiring harnesses, a/c lines, etc are needed for that particular vehicle.
Do you know how many vehicles the 2.0 turbo goes into? I mean, you could read it as the sky is falling or just a small % of defects that happen in the manufacturing process. Don't go by what you hear on boards as an absolute. It may happen and there is a TSB but I wouldn't be too worried about it. If you are worried, pay attention for any warning signs and do a used oil analysis. If anything is out of the ordinary, take it to the dealer and document it. Worst case you have the issue but it will be fixed by Ford. My point is, enjoy your Escape and don't get to worried about the what if's.
The 2.0 is in much everything except EcoSport and Trucks. There's millions on the road. If it was a larger issue it would be well documented by now.
With that many on the road there's bound to be a bad one here or there, that's just the law of averages.
Yes, Forums are often echo chambers of small problems. Its like the case of the GT350 and it eating oil or grenading engines. They make what? 3500 of them a year and if 50 blow up, its only a roughly 1.5% failure rate.
Definitely agree with both of you. And yes, enthusiast forums tend to be a little over the top. But its really all we have to keep an honest eye on things. Kinda like having a free press and free speech. You have to put up with all the noise to find the truth hidden in there somewhere. Can't rely on Motor Trend or Car and Driver cause their all paid by sponsors.
When the gasket fails it almost always erodes the block where it let go because it was not meant to have combustion against those surfaces. The 1.5 automatically gets a short block now, the SSM you posted is old. HOWEVER many times when coolant has entered the chambers for an extended time, it will gall the plug to the head and ruin the head on plug removal. The TSB for 2.0 is engine long block assemblies (6006 base number).
 First, you won't see anything in the oil. Coolant ends up in the combustion chambers only, not in the oil. If it is bad enough to get there, it will have other signs like missing at startup, empty degas bottles, overhearing and stinky burnt coolant. Second, oil analysis is NOT a warrantable justification for repair, per Ford.
Any small leaks, get repaired immediately, as low coolant can exacerbate the failure of the headgasket. Lastly, don't get your panties in a wad if you go through a very small amount of coolant between oil changes. Some loss of volume of orange coolant due to evaporation during normal use is considered normal.
Sounds similar to the cylinder block differences between the Mustang and Focus RS 2.3L EB's. Just curious, which style block does the Ranger use, cross drilled or machined reliefs?
I can't find the article but I recall reading they used the Focus RS block as the starting point for the Ranger block. The biggest changes were on the top end.
Edited by fuzzymoomoo
I'm not sure. Haven't been that deep in one yet.. which bodes well for Ranger owners. :)
two out of every 100 engines should not blow up.  ONLY a 1.5% failure rate is a very high failure rate.
100% On target. 1.5% doesn't seem like much until you are the 1.5%. And these are specialty cars. Some of which wont see many miles/year. That becomes a VERY high rate, if you compound yearly.
That makes it a common problem but not a widespread, they all do it kind of problem.
The issue is-what is an acceptable rate of engine failure? Without metrics from other engines to compare it to, the numbers inconsequential.
Just as an example having a success rate of 99.9% out of  250K cars means that roughly 1250 cars have an issue...
Not 1.5%..  i dont even think 0.1% is acceptable.  We are not talking about an overall issue with a vehicle, we are talking engine failure here.  I would never say to a customer, there are 2 vehicles out of a 100 on this lot that will have engine failure, hope you dont pick one of them lol.  YMMV.
I completely agree with you, however these things are just so complicated that a 0% failure rate is probably never going to happen. There's just way too many variables involved.  It sucks for the few that it might happen to and I really feel for them (says the guy who's 1 year old car with 15k miles on it that is currently on week 5 of getting its transmission rebuilt) and I really don't blame them for being pissed if it does happen. Fortunately that's what a warranty is for.
Big difference with something that fails at 10% for a subset of build dates under warranty and once replaced doesn’t fail again and things that fail at higher rates between 60k and 100k outside of warranty and is just as likely to fail again.
