Some advice needed... Please
Oil
42 members have voted
  1. 1. What do ya think
    • Normal oil
      21
    • Mobil 1
      21
  • Replies 73
  • Created
  • Last Reply
Top Posters In This Topic
Mobil 1 all the way. Even with the brief time I used it in my 1988 Lincoln Town Car. It helped with the gas mileage as well. I still get 24 MPG on the highway on average. And that thing has almost 180,000 miles on it! Lately I switched back (for cost reasons) to High Mileage Pennzoil which is good to use also. NEVER USE QUAKER STATE!
I wonder if the Toyota owners with engine sludge problems used Mobil 1. I'm sure it didn't help in their poorly designed sludgemobiles!
Dealers aren't making the money off of oil changes, more like a loss leader. Throw in the free safety inspection and topping off of fluids It's basicly a break even. They may however try to "upsell" a needed or not needed service in order to make some cash.
P.S. I have mine changed every 3k at the local (12 miles away since my dealership folded) dealer.
EDIT: Motorcraft filter and oil of course.
The point was dealers will almost always recommend more frequent oil changes than the mfr requires for no other reason than to drum up business - one way or the other. It doesn't mean anything with regards to engine life or oil quality.
How does that figure? Both Pennzoil and Quaker State are part of Shell Oil Company (SOPUS Products). Shell's product data sheets show no significant differences in the physical and chemical properties for Pennzoil and Quaker State branded motor oils within the same market segment. Also, the conventional oils sold under both brands meet Ford standards WSS-M2C930-A (SAE 5W-20) and WSS-M2C929-A (SAE 5W-30).
That's overkill for most of today's engines. 5,000 - 7,500 miles is command and recommended. 3/3K is just wasting oil.
Exactly! Engines and oil technology have come a long way but myths and old habits die hard. None of the owners manuals for any of my cars suggest a 3K oil change even under severe conditions.
I have a few friends in Germany that can't believe how often Americans change oil. The average German will change their oil once a year. I think that's crazy but it works for them. Germans don't drive as much as we do and oil costs a lot more, about $10 a quart.
Edited by Paul Selby
In my view, synthetic is only needed if you're doing extended drain intervals or if it's high performance/turbocharged/supercharged engine.
If it's a 'normal' engine and you're following the 3 month/3000mile drain interval, then just use regular oil.
An antiquated idea that went out with the "do not cross-rotate radial tires" nonsense.
Dealers aren't making the money off of oil changes......Throw in the free safety inspection and......
The "free safety inspections" are where they get ya......drum up at least $35-$75 additional work on every vehicle and now you've got a back shop that is turning some numbers.....ever wonder why they will rotate your tires for free?? So that can get a look at your brakes, shocks, and suspension pieces to drum up some more added on maintenance.
Read your owners manual.
Look at what "severe driving" means.
Basically, unless your start your car and drive at legal speeds continuously, without stoppping, through clean, cool air on level ground with no towing you won't have to change your oil until 7,500 mi. Severe driving is towing, stop and go, uphill, short trips, dusty roads, heat, cold.
Anyone here do "severe driving"?
Edited by DUCKRACER
Customer has the option of saying no thank you.
Only one that gets screwed on safety inspections is the dealer tech that is doing it for free.
I have used Mobil 1 on and off for many years. First experience was shortly after it came out (70's or 80s) on my Dad's car (Merc with a 400 V8) because he traveled "up north" in winter. He said the starter spun the engine like it was spring time when the temp was -20F !!
I'm using Mobil 1 exclusively on my 2007 Milan, D30. Primarily because it is readily available at Walmart at a very low price in the 5 quart jug. I almost switched to Pennzoil Platinum (which is a buck or 2 cheaper) though, when Walmart was out of stock of Mobil 1 5W-20 for 5 weeks !
I don't by the hype from Royal Purple or Amzoil.
The Motorcraft semi-synthetic is actually a good deal !!
I did read my manuals, re-read my post. Other than my truck, oil changes under severe conditions are only needed at 4,500 or 5,000 on all my other cars.
That's overkill (3 months/3,000 mile) for most of today's engines. 5,000 - 7,500 miles is command and recommended. 3/3K is just wasting oil.
I concur.
Ford has gone back and forth on 5,000/7,500 mile oil change intervals. I actually spoke to an engineers in "Fuels and Lubes" a few years ago and asked him why the flip flop. He said it was pressure from the dealers to get the customers back in more often.
If your going to quote the owners manual, you should try to be accurate !
If you feel you may not operate your vehicle under normal / everyday conditions, but
primarily under the special operating conditions outlined below
, you will need to increase the frequency of some maintenance operations.
• Towing a trailer or carrying heavy loads
• Extensive idling and/or driving at low-speeds for long distances
• Driving in dusty conditions
• Off-road operation
• Use of E85 fuel 50% of the time or greater (flex fuel vehicles only)
Not a word about hills or hot and cold !
Edited by theoldwizard
You complain that your engineer friends are losing their jobs, then go shopping at China-mart? :nonono:
Sorry to take this thread off topic, but his hypocrisy made me do it.
What hypocrisy ? I'm buying an American made product from an American retailer ? Why wouldn't I keep the extra $7-$8 in my pocket ? No auto parts stores in my neighborhood sell Mobil 1 in the 5 quart jug !
Mobil 1 has historically been a great product, but as mentioned about 2-3 years ago it started showing high iron readings in used oil analyses. Then along comes Valvoline and well, it adds up. In fact, ever since Exxon merged with Mobil the M1 line has been steadily cheapened with every major reformulation.
Until I see that M1 actually passes Seq IVA, and starts showing iron wear on par with Pennzoil Platinum in UOAs, I will not be spending my money on M1.
As far as people not using Pennzoil products, there is no reason to buy into that. Shell bought Pennzoil/QS in 2002 and they have been flawless operations ever since. Pennzoil is now essentially Shell's flagship oil line, good stuff. Even their yellow bottle conventional oil is one of the better conventional oils.
By most accounts QS is identical to Pennzoil regarding bases, but with a bit weaker/cheaper additive packages.
Edited by White99GT
You might wish to investigate what the word "synthetic" oil means. It does not mean what it originally meant. Some of the cheap synthetics have base stocks barely better than petroleum based oils. And some of the synthetics use grade 4 and 5 base stocks, and are outstanding products. You can look up what all this means.
Suffice to say....good synthetic oils will perform in extreme hot and cold conditions better than traditional oils. They also claim to hold solids in suspension better, thus giving a longer service life. They have a much higher flash point, so you can run the 5W and 0W viscosities without fear in hard working engines. No need for 10W oil use. So synthetic oils are superior, that's a fact.
However....I don't live in Alaska or on the moon in a NASA lunar vehicle. I also have proper functioning cooling systems in all my cars. And I also change my oil in all my vehicles usually about every 6 months, or 5000 miles. I don't tow anything. So no extreme duty for my vehicles.
And since I know many well maintained engines to last well over 200,000 miles with no repair, that used plain petroleum oils in manufacturers suggested viscosoty, I see no need for me to use synthetic oils. Although I have used them in the past in many of my vehicles. The last time in a 550 RWHP supercharged 98 Cobra without a A/A cooler. I needed synehrtic oil for that application . But it would be a waste of money for me to use synthetic oil in current vehicles.
Agreed. PP is showing as good of results if not better than M1 these days. Pennzoil yellow bottle and motorcraft are equals from what I can tell. Run conventional and change it at 5K and you will be fine. Pick your brand as I dont think it matters. Walmart brand shows well in oil analysis. Personally, I like motorcraft and pennzoil but that is out of habit more than anything else. This entire conversation is over rated as long as you change your oil regularly.
3K intervals are a thing of the past and a huge waste of money. My friend owns a quick change oil place and changes his own oil when the GM oil life monitor goes off and that is around 7 or 8 k most of the time. This is on a GM 4.3 and it has 250K on it and he just dumps in what ever oil. He loves people who come back every 3K though.
Speaking of which, I wish Ford would come up with something like the GM oil life monitor. That thing has proven to be reliable even with extreme mileage. The oil analysis prove it time and time again with all sorts of brands of oil. Why does Ford not offer something like this?
I use Motorcraft 5w20 oil and Motorcraft FL820S filter and change it every 3,000 miles myself. Independant testing has shown both to be excellent quality. Amazing how many people think Ford parts are not good enough for their Ford engine!?
Oh, and about the mechanic who is trying to get "upsell" off of oil changes...just let him miss some problem anywhere on the vehicle while he has it in for that loss-leader oil change and see how fast the customer blames him, the department, the dealership, Ford Motor Co, ect...untill someone else pays for his repair "because you professionals should have seen that."
http://home.mindspring.com/~ed_white/id7.html
Here is a site where the guy has disassembled filters with pictures and discussion for comparison purposes. The Motorcraft FL-820S, and Ford Racing version of it are quite different. The Ford Racing filter has more media and more filter pleats for even higher levels of protection. A real good site for all those "filter hawks" out there....
Thanks Twin! I knew there was a difference. I was told the FRPP maintains oil pressure better than the Motorcraft which is the leading factor in choosing to run it at certain times.
Motorcraft oil is made by conoco phillips. I cant remember who makes the filters but I think it might be wix?? Anyway, Ford does not make this stuff they only market it. I believe the oil is the same as Kendall Tropartic.
