By DeluxeStang · Posted
I think that's a safe bet. There were rumors of it using the maverick name, but those rumors dated all the way back to like 2023/24 whereas the ranchero rumors were more modern. Lower, wider, sleek, RWD performance ute with a unibody platform. Ranchero makes a lot of sense. -
Zesty best me to it, but you can see what appears to be the actual windows here. I've marked their basic outline with a black marker, and then did an zoomed out version as well. With the windows at that level, it almost gives me explorer sport trac vibes. -
Maybe its name will be Ranchero! 😉
By twintornados · Posted
I'm sure the aftermarket will step in with lift kits for it... -
It's only a priority if they have a product that needs to go there. I think they planned to close it a couple times and just never pulled the trigger. I think the cost to remodel was pretty high.
It's definitely lower than the maverick at least. -
I think its more towards 62 or 66 inches. The Mazda isn’t much taller than it, it looks similarish to the Subaru Forster it passes, and David Tracy (journalist) who is 5’8” is standing on a 6” curb and appears around 1 foot taller than it. edit: checking back to when Doug Field was leaving and Farley took an IG photo standing next to the truck, it seems about 8 inches shorter than Farley. 60 inches might be right. Farley (based upon the F1 photo op in 2023 when he stood next to Verstappen, Perez, Horner, and Riccardo he appeared ~2 inches shorter than Riccardo who is 5’10”) is at most 5’8” in heels. as you can see he is perhaps 7 to 8 inches taller than the truck here. That provides 60 inches.
If you look through the interior and at the driver's side glass, you can see that white camo covering up part of the lower glass, prob 1-2 inches so the glass is at least that much lower. -
I tried to get interior sides of the camo, but hard to tell in this video: We can see on the passenger side with the way the camo tapers back that the beltline at minimum sits at this red line, because you can see the window edge go at least that low.
