By DeluxeStang · Posted
Yeah I'm probably gonna have it done this spring/summer. The car should only rack up about 1,500 miles during that time so I think it'll be fine. Gonna replace the pads around that time as well because they're pretty worn after 40k. Trying to figure out which to do first, pads or fluid, or if it even matters which is done first. -
It's not an immediate problem but water in the fluid can cause rust over a long period. It can also boil under heavy use but that's really a track problem not a street problem. Also when you bleed when changing pads you're replacing a lot of it. As for not doing it in the 60s or 70s the car never lasted long enough for it to be a problem!
2 potential reasons. Commodity hold (parts shortage) No Dealership allocation - usually means there are others ahead of you in queue. They may have jumped other orders ahead of yours. No way to know for sure. If it's a commodity hold they can tell you which parts are holding it up. If they can't tell you then ask for your priority. Lower is better. I think 3 may be the lowest the dealer can go. 10 is ok. 19 is the worst. But it still depends on who else is in queue and their priority. If parts and allocation are available Ford picks the lowest priority order first (more or less).
I believe the smaller one with a filled in grille was a focus design, and the larger one was a fusion. -
By Sherminator98 · Posted
The Scout looks better IMO, I wouldn't touch either with reliability -
Uh two completely but similar looking vehicles. -
By Chris F250 · Posted
I ordered a 2027 F250 Platinum June of this year, and I was told that I should receive it in September. I got an email from ford inn August that it would be moved out to September, then November then December then January and now its February. The dealership that they have seen orders take 1 to 2 years. I haven't heard any reason why it's taken so long. Can someone know how I can find out why it's taken so long? -
You guys have lost me. I remember reading that the T6.2 platform was developed to accommodate future electrification but it sounds like you are talking about something different?
I thought there was one but it was dropped to hit timelines?
As someone that works on my own stuff, a "routine" brake fluid change has never been on my list. I have 60+ year old vehicles that I've never even looked at the fluid. Don't worry about it until the brake lines rot out and it's time to do a full rebuild.
