C&D: 2015 Ford Transit 350 Wagon EcoBoost V-6 Review
@Biker...different colors so you feel like youre getting anew car every month?.....lol...I will come right out and say it...my impression of the diesel is its old tech and ancient, behind the times power and torque wise...my guess is theres a more modern replacement in the mix....which could quite possibly see usage in the F-150, F250 and expedition.....
Edited by Deanh
You're probably right.
Apparently, the new Duramax 2.8 puts out 181 hp and 369 lb-ft.
Though, it probably wouldn't be too difficult to tweak the 3.2's numbers.
for my use the Efficiency of the Power stroke will pay for itself in no time, we are generally putting 30,000+ miles on our vehicle per year.
ACROSS THE ROAD ITS ABOUT $1.50 CHEAPER....oooops, caps....anyways....nope, my bet is its the price jump, even running locates for $hits and giggles, shows other dealers didn't order diesel for inventory either....
So that's the issue... no SoCal dealers even bother ordering any diesel. Chicken or egg first?
I'm not an expert or anything but I know the E-series diesel when it was still available was precious commodity. Now that Ford finally has diesel van again, no one wants it? I find that a little hard to believe.
Exactly.
The beauty of the Transit is the improved fuel efficiency over the previous E150-350.
The 3.7 V6 effectively replaces the 4.6 2V while the 3.5 EB replaces the 5.4 2V.
It's similar to what happened in '10 F150 with then new 3.7 and 3.5 EB. engines
is there a place for the 2.7 EB in Transit?
Exactly.
The question I would ask is there a place for the Ecoboost 2.3?
When there are good petrol alternatives, who would want a diesel ?
Diesel engines have so many things against them. Higher initial cost, DEF, more expensive oil and filter changes.
We will see I am hoping to split 4 Diesel and 4 3.7 transit to compare the cost.
I'm not sure the 2.7 or 2.3 EB would be a good idea.
Doesn't the 2.7 work for the F-150 because of the lighter weight aluminum body (which still has a steel frame)?
Also, I'm not sure it would be a good replacement for the 3.7. They need a naturally aspirated engine for CNG and LPG conversions, don't they?
Edited by zipnzap
I don't think anyone is suggesting replacing the 3.7 with the 2.3 or 2.7, just an additional option for those that may want it
Exactly.
3.5 EB replaced the V10... not the 5.4 V8.
I would be shocked if 2.7 EB doesn't show up at some point because the output is a better fit for what Ford wants to accomplish (i.e. 5.4 V8 replacement) than the 3.5 EB. But 2.7 EB didn't make it in Transit at launch... probably because Ford wanted to prioritize 2.7 EB for F-150.
3.7 V6 (275hp / 260 lb-ft) ==> replaced 4.6 V8 (225hp / 286 lb-ft)
2.7 EB (325hp / 375 lb-ft in F-150) ==> would replace 5.4 V8 (255hp / 323 lb-ft) - in Transit, the 2.7 EB would be detuned to around ~ 300hp / 325 lb-ft similar to the 3.5 EB detune from F-150 to Transit
3.5 EB (310hp / 400 lb-ft) ==> technically replaced the 6.8 V10 (305hp / 420 lb-ft) - if 2.7 EB shows up, Ford will probably up-rate the 3.5 EB a bit and increase the GVWR for the T-350 and T-350 HD to close the gap with E-350, which can be gracefully retired at that point.
Edited by bzcat
2.3 EB should be interesting... I think it will work very well in T-150 or maybe even a T-100 for people that need the volume but not the weight rating.
But at that point, Ford may be better off just selling the midsize Transit Custom.
Would this require some sort of weight reduction on the chassis itself, probably for the sake of engine longevity?
The problem is that Ford isn't even using the Ecoboost in the cutaways, for whatever reason.
The replacement would probably have to be naturally aspirated.
My feeling is that GVWR limit on the transit is related to structure not engine.
I think Ford was wise in there choice of engines on the North American transit.
I think the Addition of the 10 Speed will open up more engine possibilities, right now I think the current lineup is best in class.
Transit custom is an interesting vehicle for north america, the 2.3 would be perfect for it.
The cutaways represent how that segment views perfromance, it doesn't care. OPEX is far more important.
That's a good point. I forgot all about the midsize transit
