2013 Ford Escape World Debut
Seriously? .5" less ground clearance for a soft-roader is a big deal? You cannot honestly say that is a make-or-break difference. How many Escape buyers know the ground clearance their vehicle has anyway?
sorry V8...thats TOTAL scab picking...seriously 1/2 an inch....PUMP YOUR TIRES UP.....and 4 inches in turning radius.....honestly????????? :banghead:
I was simply responding to the statement "Retains all the capabilities of the previous generation". Didn't say the loss didn't improve ride quality or anything. But anytime you lose nearly a 1/2 foot of ground clearance, clearly you are decreasing parts of its capability. Also didn't say it was a make or break deal, I wouldn't have bought one anyways, but by the stance it appears to look more like Subaru ground clearance.
Wow, see my last post. But simply put, they are loses, no matter how insignificant you feel they are.
And yes, it offers improvements over the outgoing model. Has it's good and bad moves, IMHO. Worst is the design on how it looks like a Focus front end was mashed together with more of a CRV/Tucson cabin. While from certain camera angles it looks decent. Every profile image shows this flaw. Again, just my opinon. If you like/love it great. Go buy one.
Edited by V8-X
Exactly!
pretty dramatic change, and I would have bought the old one ( if I was in the market ) for two reasons which outweighed the dated styling and its "crude" nature A) its refreshing simplicity and B) 1000 rebate with 0 % financing for 60 months.....and thats a BIG part of wht the outgoing models garnishes so much love. But, its time to move on obviously, road, wind and engine noise are so yesterday.
Half an inch, not half a foot.
Half an inch - NOT half a foot!
I wouldnt say 1/2 an inch has ANYTHING to do with capabilities......neither does a turning radius of a mere 4 inches....when is either going to effect capabilities in real world conditions.....
Got ya, my bad, I apologize. Must have misread .5" for 5". And maybe it's some of the low profile tires and plastic siding playing tricks on my eyes. But it doesn't appear to have similar ground clearance.
I wonder what points they are comparing to make that ground clearance statement. I've seen some ridiculous comparisons in the past of ground clearance, so just intrigued.
Edited by V8-X
It is supposed to be from the lowest hanging item on the underside of the vehicle. (Though some people do not include the exhaust when they measure....I'm pretty sure manufacturers do)
Exactly, and that could be of issue. Say for example, the lowest point on the outgoing Escape was the outer most portion of the Control Arm, and the lowest point on this Escape is the frame or muffler. In that situation, the older Escape would have a decided advantage, because as it was conquering obstacles, the control arm would go up/down with the tire, and means the undercarriage is higher. Whereas if the frame/muffler on this new Escape is the lowest point, it'd cause the new Escape to get hung up much easier. Not saying this is true or not about the old/new Escape. Just wonder what are the two point they are comparing between each model to make a more educated decision on the true difference.
Kind of like trucks with a IFS and SFA. Typically the lowest point on the SFA axle is the pumpkin, where as the IFS is the end of the control arm. In most cases, it's a little easier to get the pumpkin hung up on an object than it would be the end of the control arm. I prefer the simplicity of the SFA, but understand the IFS has it's benefits here and there.
Edited by V8-X
Let me re-phrase your statement to say the exact same thing, but give a decidedly different point of view (ie: not soundling like bashing the new Escape without having details). Here goes:
Exactly, and that could be of issue. Say for example, the lowest point on the outgoing new Escape was the outer most portion of the Control Arm, and the lowest point on this the outgoing Escape is the frame or muffler. In that situation, the older new Escape would have a decided advantage, because as it was conquering obstacles, the control arm would go up/down with the tire, and means the undercarriage is higher. Whereas if the frame/muffler on this new the outgoing Escape is the lowest point, it'd cause the new old Escape to get hung up much easier. Not saying this is true or not about the old/new Escape. Just wonder what are the two point they are comparing between each model to make a more educated decision on the true difference.
Again, it is a soft-roader, so it doesn't make any difference! It will clear all speed bumps and non-rock crawling situations with aplomb!
Why update the 2.5? Why not just use the Focus 2.0 GDI? Could have been tuned to bump the torque up a bit, probably increase base model fuel efficiency as well. I'll be disappointed if the 2013 Fusion uses the 2.5 instead of the GDI 2.0.
Most likely because of Torque requirements. I don't think the GDI 2.0L puts out enough torque...not to mention the 2.5L is cheaper without the GDI on it.
And I'd expect the Fusion to have the same engine lineup sans the 1.6L EB as the Escape too
* sidenote, on autoblog after a couple of the usual imbecile sideswipes at Ford as a whole, our "buddy" P71/ Matt/ Z71SLVY, True Voice had his comments deleted and is seemingly unable to post any nasty remarks....now all he can apparently do is vote down positive comments....sheesh.... :banghead:
The same bozo put one on the previous gen Focus. Lasted 1 year IIRC.
Not my cup of tea either if its functional I have no issue, but the SWATH of chrome is heavy handed...treat chrome like jewelry Ford, compliment the contours dont blatantly draw attention to it.....
This, or a Lincoln Escape, could make a very good daily driver ...
Personally, I had hoped the Kuga would go to the Lincoln/Mercury dealers, keeping the original name and a much more "SUV-styled" version be sold under the Escape badge.
I still think there is room for 2 vehicles with different "green houses" in the US, but I can NOT see a "traditional" styled SUV in the Lincoln line up..
The Lincoln Version will be on the same platform as the escape. some tooling is done in the plant for it.
Edited by Jr.f
