Well Cummins announced availability of the gasoline version -87 octane- of the 6.7. 660lb-ft of torque.
I'm sure it will be far more costly than a 7.3 Ford but checknout this response from Paccar;
Cummins says the engine has undergone 2 million miles of testing. It was the first B Series engine built on the HELM platform, designed to reduce emissions, increase fuel efficiency and able to be modified to run on alternative fuels. HELM stands for “Higher Efficiency, Lower emissions and Multiple fuels” and was launched in 2024 to help customers adapt to future emissions requirements and meet emissions-reduction goals.
“The engine was validated against the same standards as Cummins diesel B6.7 engine,” said Kevin Haygood, Kenworth’s assistant general manager for sales and marketing manager. “With environmental regulations changing, it spurred us to offer another engine option to our customers. The new Cummins B6.7 Octane engine will meet stringent emission regulations, so we expect it to be a popular option in California and other states that have adopted CARB’s standards. It can be a great fit for many of our customers’ applications, especially in P&D (pickup and delivery) and towing applications. We also see it being popular for the lease and rental markets, as well as for landscapers, where those behind the wheel are used to driving gas-powered vehicles.”
As I've said more than once, Ford was in a good position to push the 650/750 7.3 on the west coast. But no- I'm afraid those that say Ford is done with class 6 and 7 are correct. The move of class 6 and 7 from Bluediamond to OAP was just to placate UAW during last negotiations.
The air brake debacle and the fact they wouldn't spend any money on that but just offer BS excuses says they are done.
Fordman...guess I'm done standing on the hill🤔
Same chassis, same basic powertrains, exterior styling that's basically s550 with some additional edges, etc. It's not bad, but we know enthusiasts unlike conventional buyers tend to want significant changes in styling and performance with each generation.
I don’t know if it’ll work on your generation of truck, but it’ll take a little while if it does. The problem on the 12th Gen trucks was that the BMS wasn’t allowing the charging system to sufficiently charge the battery (maybe because of short trips, I don’t remember), so it was legitimately turning the system off to save battery. After disconnecting the BMS, it took a few trips for the charging system to get the battery back up to full capacity, and that’s when the truck stopped turning everything off right after killing the ignition.
Also, on the 12th Gen trucks, there were sensors on both power leads from the battery. One was the BMS that was safe to unplug, but the other one had to stay connected. I’ve long forgotten what the “other one” was, if I ever knew at all.
So is the engineering for the 3.0L ecoboost (Explorer and Bronco).
I think the 5.0 would be ok for a Mustang 4 door but if they do a Lincoln version it needs the ecoboost.
