Oh I totally agree. Ford backs themselves in a corner constantly and then gets stuck with only two options - 1) sticking with a questionable plan, or 2) pausing everything and starting over, causing years-long delays in product cadence. And they seem to go with option 2 over and over.
Flat Rock can't produce the crossover shapes/heights that Ford wants.
Oakville (the "Canada" plant you're referring to) is set to produce Super Duty. I'd agree that the Mach E plant has to be under capacity. But I'd question the ability for it to produce both ICE and BEV on the same line. I can't speak to Wayne.
Having zero flexibility in your production capacity is poor management as far as I’m concerned. I swear Ford is always in crisis mode. You can never make the same mistake twice, because the second time you make it, it's not a mistake; it's a choice, and they have repeatedly made choices that have affected their ability to produce vehicles.
I would consider it as well. Thank you for bringing this up T-dubz. I’ve been wanting to say something myself, but I couldn’t get past the ads every time I thought about it, lol. The ads are beyond ridiculous on here. Sometimes I just give up.
I just assumed the grand part of the name was to indicate the longer version like Expedition/Max.
Knowing two people that bought these, and have had a multitude of serious issues, marked it off our list immediately when shopping for a new car. Came down to Yukon XL and Expedition Max. Even though the wagoneer could be had ~$10k cheaper.
Range of only 255 miles is a bit disappointing given 65 kWh battery capacity which makes it just under 4 miles per kWh. That’s worse than previous Tesla Model 3 which got 273 miles from 60 kWh, with only +/- 57.5 kWh of that useable. It shows in real terms how important efficiency is, especially aerodynamics. Anyway, charging rate of over 410 miler per hour is what Bolt needed most. While likely still best for city and urban driving it should not be too bad to take on short road trips once in a while. Traveling from Houston to Dallas, Austin, or San Antonio for example should only require one short charging stop.
Will be interesting how sales compare to new Nissan Leaf. They’re quite different but in similar price range.
I just find it funny how Farley or Musk spin a topic to suit their narrative
No buyer ever asked for overly complicated vehicles that was always done by manufacturers to suit their own ends. It was all to boost profits but look at where we are now, vehicles get more expensive while CEOs cry poor…….
