Seems to be a bit of willful ignorance going on here that he is completely ignoring:
The 2.0L made 160 horsepower at 6,500 RPM and 146 pound-feet of torque in non-ecoboost form
2.5L 168 horsepower and 170 lb-ft of torque in non-hybrid form
2.5L Hybrid is rated at 192 horsepower and 155 pound-feet of torque combined with the hybrid motor. The engine alone 162 HP
The 1.5L Ecoboost makes 181HP and 190 ft lbs
2.0L Ecoboost makes 250 horsepower and 280 lb-ft of torque
The 3.0L V6 made 240HP and 231 ft of torque
The whole point of the Ecoboost engines where to downsize from a V6 and a larger I4 to packages that give you more power and equal or better MPGs vs their larger counterparts.
The power numbers from the 2.5L are from 15 years ago, so there is a decent amount of loss from going to an Atkinson cycle given possible improvements in the power output of the engine over time. Like you said a NA 1.5L would be lucky to hit 100-120HP and a hybrid setup would maybe add another 30-40HP if you where lucky,
Yeah, unfortunately solid state batteries could still be many years away. It’s not just the technology, which is indeed promising, but also the higher cost per kWh. Projected prices I’ve seen are still much higher than present LFP as example.
Ford's use of keyed ignitions vary across the lineup. Some models are all push button start, and even those are not all "intelligent access". Keys do not bother me, but, it seem most want that feature and not sure what manufacturers still use keyed ignitions. Own a 2014 F350 and 2011 Mustang GT with keyed ignitions, and have a 2023 Bronco Basequatch with basic push button start which I prefer over "intelligent access".
I also do not like the trend to all digital clusters, bigger screens and less buttons and knobs!
22 f350 6.7 4wd While pulling skid steer 11,000lb gravel road in 4 Hi the truck pulled hard to the left, I thought a tire went down, it stopped pulling, did it again to the right this time and started squealing really loudly. I stopped, felt all the hubs, nothing hot, full of air. Drove off and it did not do it again. The jake brake was also engaged!
Anyone experience something like this?
Howdy guys, New to the group. I read a lot about the 30 min shut off at idle, I have a 2025 F-250 XL, and it idles as long as an hour and a half, that's the most I've let it run unattended? I bought it new and never had to change the settings. The only thing I notice that different from most post is I have a Key type ignition, not a push button. Any ideas why. Thanks Don
The article you quoted implies you can replace a 1.5 turbo with a NA 1.5 hybrid. But most hybrids are 2.5 Atkinson cycle for max mpg and a 1.5 Atkinson cycle won’t have enough power even with hybrid assist.
The biggest challenge that Ford faces is getting enough buyers interested in its BEVs,
EREVs are going to be even less desirable because of the larger battery plus ICE.
One regulation for EREVs prevents charge sustain, that’s a big issue for some buyers.
