Yea, Rivian R2 won some SUV of the Year competition recently. Both Scout and Rivian use Rivian based software now that the VW Cariad shit show has concluded.
As some of my friends have nostalgia-themed car collecting occur, my decades (it felt like centuries) in parts always color my opinions. Whenever they fixate on a "malaise era" car, my advice it fairly typical: 1. If the car isn't a museum piece, consider the drivetrain, brakes, and chassis to be mandatory points of improvement. 2. Remember that our car industry had several years where even 400+ cubic inches barely achieved 200 vapor-locking horsepower. 3. Modern crate engine options are amazing, and even the lower levels are typical better than what was in there. 4. Modern fuel injection and ignition systems have half or less vacuum hoses to deal with. 5. Chassis stiffening is a great place to start. 6. The "Bandit" Trans Ams would get humiliated by an average hot hatch, today. Keep that in mind. 7. A build on an underdog like a Mustang II stands out among more common fare. 8. You've likely gotten used to rack and pinion steering. See if retrofits exist for your project, you'll thank me. 9. Keep at least one good copy of your parts list(s) in the envelope with your registration, because everything wears/breaks. 10. Nothing is cooler than circa-1970 Ford/Mercury "sportsroof" cars.
By fordmantpw · Posted
If you ordered the digital rearview camera, that's holding up a lot of 2027 Super Duties. My 2022 F350 took 14 months from order to delivery, but that was due to a lot of covid issues. My guess is the digital rearview camera...it's a commodity hold as akirby mentioned. -
By Harley Lover · Posted
Agree on reliability, I prefer the Rivians. -
Pads then fluid since you have to bleed them anyway.
For those of you that collect diecast vehicle replicas, a Ford WT-9000 is finally available. I don't think a replica Ford WT has ever been available before, either as a diecast or a plastic kit. Ford's first 'real' class 8 truck: https://www.diecastdirect.com/product/59695/IXO-Models
By DeluxeStang · Posted
Yeah I'm probably gonna have it done this spring/summer. The car should only rack up about 1,500 miles during that time so I think it'll be fine. Gonna replace the pads around that time as well because they're pretty worn after 40k. Trying to figure out which to do first, pads or fluid, or if it even matters which is done first. -
It's not an immediate problem but water in the fluid can cause rust over a long period. It can also boil under heavy use but that's really a track problem not a street problem. Also when you bleed when changing pads you're replacing a lot of it. As for not doing it in the 60s or 70s the car never lasted long enough for it to be a problem!
2 potential reasons. Commodity hold (parts shortage) No Dealership allocation - usually means there are others ahead of you in queue. They may have jumped other orders ahead of yours. No way to know for sure. If it's a commodity hold they can tell you which parts are holding it up. If they can't tell you then ask for your priority. Lower is better. I think 3 may be the lowest the dealer can go. 10 is ok. 19 is the worst. But it still depends on who else is in queue and their priority. If parts and allocation are available Ford picks the lowest priority order first (more or less).
I believe the smaller one with a filled in grille was a focus design, and the larger one was a fusion.
