@willyjr yes, I already joined some groups but a friend of mine also suggest give suggestion on contacting local guides here https://gowithguide.com/egypt , Thank you so much for your help. I'll update you if I got one
Thanks for your feedback mate. This might be a stupid question, but would this approach be more of a permanent solution, or more of just a temporary bandaid? I have to pop the hood to swap a new air filter in anyways this weekend, so I could do that while I'm under there.
On our 22 it changes dramatically between 1, 2 and 3 if you’re cooling down a hot vehicle. Maybe the new o es are reversed? Try all 3 settings.
You should also be able to set the fan speed to low and it should stay there while it adjusts the air temp automatically.
Not the fan speed, the temperature setting, and those are controlled by two tiny carrots that are hard to hit just right when driving -- or even to see them at times. I often have to tap it several times to get it to register. The fan speed is a much easier screen adjustment to make and it doesn't bother me. As for the fan speed on auto, if you are talking about adjusting it to 1, 2 or 3, I never have put it on anything higher than 1 and it is often still too much air at times (hence the reducing the speed manually, which again doesn't really bother me). Or is there is some other limiter I have to find in settings?
Second the recommendation about contacting some UAW locals in the region where your grandpa worked. When I worked for Ford/Visteon/ACH, UAW Local 1111 had historical records of that nature in their archives.
My 2015 mks ac has an electrical problem. The sunroof drains were stopped up and water leaked on the control panel on the dash. I fixed the problem but now the ac will not work. I checked the fuses under the hood, and they are good. I have-not checked the relay because I don't know how to. I cannot find the cabin fuse box. If you can help me, it would help me greatly.
sincerely,
Tony Watkins
You could always try disconnecting the battery for a little and seeing if you can have the transmission re-learn your driving style to see if that helps. Just to rule that out before doing anything more serious.
