Except that the 5.0L Coyote never was installed transversely in any Ford product.....closest was the 4.6L In Tech modular V8 that was under the hood of the 9th Generation Lincoln Continental and it was detuned so as not to destroy the transaxle.
CD6 is too expensive that’s why CD6 projects for Mustang and the four door sedan were scrapped.
If the business plan didn’t work then, it certainly won’t work today.
The thing about these plans is that to Ford, it’s seems like a logical step
considering all the other F150 manufacturing that’s continuing at the plant.
The question is , do they add an ICE to Lightning or do the easy way out
by adding a bigger battery to the Powerboost hybrid and call that job done?
Or is it something in between that uses the Lightning’s electric motors and drives, a smallish battery and an ICE Gen set?
I'm sure Cologne will be closed when Ford switches to rebadged Renault EV instead of building its own VW MEB. Cologne has the same problem as Saarlouis... German union and wages (note: this is not an anti-union rant... I'm just trying to explain why Ford is angling to do a deal in Spain instead of Germany). Also quite possible Ford has some kind of covenant in the VW agreement that restrict them from building something else besides MEB at Cologne.
Valencia has enough capacity to contract build Geely EVs but Geely is only interested in something like this because of political expediency and taking advantage of Ford's weak bargaining position. A lot of European countries are starting to worry about Chinese auto industry wiping out their own so a big splashy investment by Chinese OEM to build cars in EU's traditional car building countries could backfire. Having Ford build your car and saving Spanish jobs from being cut is much better press. Geely could also just build its Zeekr cars at Volvo plants instead but that has its own problem because the high costs of building cars in Sweden.
There is no way Geely will enter into an agreement like this without a call option to buy the plant from Ford at some future point. Remember Ford was actively hoping to sell Saarlouis to BYD before that deal fell apart because BYD didn't want to deal with German unions and high German wages. Spain on the other hand, is a lot more attractive. This is why the deal is around Valencia not Cologne.
Looks like F-53 stripped chassis was discontinued after 2024....only one on Ford Pro is F-59 stripped....the F-59, however, uses the 7.3L/6R combo according to the Ford Pro site.
Update: According to Google, Ford still makes the F-53...but it is not on the Ford Pro site.
The 650 and 750 6.7L Powerstroke trucks use the 10R, but the 7.3L gasoline versions use the 6R. I think the F53 stripped chassis may also use the 6R with gas engines.
I really wish the 6R140 was available with the 7.3L or 6.8L gasoline engines in the 250 and 350.
