The article you quoted implies you can replace a 1.5 turbo with a NA 1.5 hybrid. But most hybrids are 2.5 Atkinson cycle for max mpg and a 1.5 Atkinson cycle won’t have enough power even with hybrid assist.
The biggest challenge that Ford faces is getting enough buyers interested in its BEVs,
EREVs are going to be even less desirable because of the larger battery plus ICE.
One regulation for EREVs prevents charge sustain, that’s a big issue for some buyers.
I believe EREVs are a good choice for larger vehicles, but for small, light, areo dynamic vehicles, that's basically the perfect use case for EVs. Apparently a lot of modern apartments are being built with charging stations in mind, or give tenants the option to have a charging station installed at their parking space if they pay for it. We'll see how that works out.
It's also worth noting all future Ford EVs will have access to Tesla superchargers which are everywhere, and we're see a lot of charging stations pop up at work locations, restaurants, movie theaters, and shopping centers. Do you can pretty much charge your EV wherever you go.
I'm not as concerned about the availability of chargers as much as I was 10 years ago.
I should listen to Mr Spock’s advice when he said "It would be impossible to discuss the subject without a common frame-of-reference". It’s same here which makes it seem like we are speaking different languages.
If you actually believe your own words then ask Ford why their popular hybrid powertrain, as used in Maverick and various models, uses a 2.5L naturally-aspirated engine instead of replacing the hybrid’s engine with Ford’s 1.5L EB. And while at it, ask Toyota the same exact question given their popular hybrid powertrain installed in various vehicles also relies on a 2.5L NA engine instead of their 1.5L turbo. And don’t forget Honda too, though their improved hybrid powertrain has allowed use of smaller 2.0L NA engine.
Wrong. A hybrid still relies on engine power alone to propel the vehicle most of the time. To replace a 1.5eb requires a 2.5l NA engine. To replace a 2.0eb requires a 3.5L NA v6. Unless you’re willing to compromise performance with a much smaller NA engine. Ecoboosts use turbos to downsize the engine making it lighter and more efficient while still providing adequate power when needed. Even a 2.0L NA engine could be replaced with a 1.0 or 1.5eb. This whole push for “less complexity” without turbos is a red herring. The technology is reliable enough that it’s a non factor.
Let’s see the data. Nothing I said has anything to do with income or affordability. In fact it supports using cheaper engines for base models because most buyers don’t care. But you think bargain buyers want simplicity like a NA 2.5 over a 1.5 turbo and we’re trying to tell you they just don’t care. What matters is price, price, price, styling and mpg.
