Because it works more often than not! I saw a meme that asked why IT folks are so snippy with users sometimes. Because I once had to drive 3 hours to plug in a server that 3 different people assured me was plugged in.
By fordmantpw · Posted
As an IT guy, that's my thoughts. That's also the first solution I give anyone when any type of electronic device isn't working! -
By HotRunrGuy · Posted
Maybe it just needed a good ole' Ctl-Alt-Del (disconnected from power for a bit then plugged back in)? HRG -
By twintornados · Posted
Maybe take a look over at "GE Monogram News"? -
Borg's comments on said rendering..... Nope It's very straight-sided, no pronounced fender flares (or door handles), but it does have some creased sheetmetal hidden by the upper body camo (which is also hiding the Mach E-style handles). Front end is not accurate at all, I mean they show part of the front end in their teaser photos. The 3D printed model also alludes to the body styling to some extent, but seems to be exaggerated.
Here's a weird scenario that I can't explain. Prior to this last power outage and after several other, shorter outages, the digital electric clock on my GE gas range started loosing time. Like 20 minutes every hour. This went on for several days. I just assumed it had taken too many power surges and was toast. Fortunately, the timer still worked fine which was actually a bigger concern. None of the other electric powered clocks in the house had any issue with keeping the correct time. I had to reset them after every power outage but that's all. What's really baffling is that while on generator power for several hours that clock started working perfectly again and has been fine even after the power came back from the utility co. Any ideas? You would think that if it were, say, a low voltage issue from the utility co that it would have shown up elsewhere at the same time.
By DeluxeStang · Posted
You started something that can't be finished. -
Again, maybe that's a valid point with class 3 through 5 Super Duty trucks but the 650's and 750's are a different ball game anyway and aside from similar powertrains (and similar powertrain problems!) they don't share much. If the fleet has vehicles up through class 7 and 8 it would probably be better to source their class 6 trucks from the same vendor they get the larger trucks from if they are looking for consistancy. Which is what I see and is consisitant with my own fleet experiences.
But they would be Fords if Ford built class 8 AND Ford sent sales agents out to pitch class 6 thru 8! Look at the sales figures for Ford mediums WITHOUT EVEN TRYING!
