The difference is tq at the wheels, Rick did the math for you but gearing and rpm make it effectively the same thing. With ICE you usually run out of RPM (or gears in the trans, which is why they keep adding more) on the top end when you increase gearing, but if GM's claims about more RPM out of the electric motor and efficient are true then you aren't giving anything up.
I don't know if you ever built a drag car or race car, but you usually increase gear ratio in the rear until you're trapping at or close the rev limiter in top gear, which makes you faster but you sacrifice top end and especially highway manners if it's not an OD trans.. but it gets you off the line quicker and makes the car faster in the 1/4 or whatever you're doing. If there's more RPM available then there isn't much of a trade off.
Ford is making a big hoopla out of CE1 because its mass roll out plan for BEV F150 is looking decidedly over blown.
Nobody really knows if enough buyers will be interested in the new mid sized BEVs but really what else can Ford do?
Back when Ford delayed the three row BEV the first time, that was to give Mache more production space and to give battery production capacity over to e-Transit.
The plant where the fire happened may be closed down until early next year. The F-150 sales crown is probably safe this year. Next year too, unless something else happens.
There's also the KC (F150) plant and KTP (Super Duty) that it doesn't mention as decreasing production. I think Expedition/Navigator were cut to keep the SD going.
Hopefully Ford will be able to source aluminum from another supplier. Even if it does require paying tariffs. That’s an incredible sales streak to risk for a short term production and profit issue.
