Given how the weather has been around here in the winter, the impact of cold temps (freezing) would be almost negligible. If you can charge at home, does it really matter if you only get 150 miles or so of range-unless your driving an hour and half or so to work?
One of my coworkers has a Bolt and they don't even have level two charging at home because they don't drive that much.
They’re kind of forced to because of the production situation. If they were able to give Expy/Navi their own plants again they could be more aggressive.
It’s not perfect for the cold regions. You basically can cut the range in half during the winter, so you would need at least the 300 mile battery option you referenced.
The dealer has the ability to prevent delivery of the truck to you? I would rather the state test it to be sure the dealer isn’t trying to collect $70 from you.
So purchased my truck from Wyoming and has factory tinted driver and passenger side windows. label on window says Ford Solar tint transp. 70% min.
the law states 30% but the dealer failed it.
Are they wrong they offered to remove it for $35 each?
