Feds Investigating Nearly 1.3 Million Ford F-150 Pickups with Serious Transmission Problems - Autoblog
The Blue Oval is facing a new headache over older pickup trucks. The National Highway Traffic Safety Administration opened a preliminary investigation into 2015-2017 Ford F-150 trucks on 21 March 2025 due to reports of issues with 6R80 or 10R80 automatic transmissions that may unexpectedly downshift without warning or driver input. The NHTSA has now upgraded that query into a full investigation, covering 1,270,970 examples of the pickup, after more than 60 percent of surveyed owners reported problems to the NHTSA’s Office of Defects Investigation (ODI). While this is not yet a recall, the frequency of complaints may lead to one.
They didn't put the gas struts on the Bronco at all, just a prop rod. I wound up buying the "Ford Performance" gas struts for it that actually lift the hood higher than the prop rod did.
Looks like Ford takes over both assets and liabilities for both plants but I also read this in the linked story.
I separated the sentences below to help clarify
This has to be a projected loss of income that Ford can justify as part of TE3 not proceeding
so definitely looks like a paperless until Ford retools for those LFP batteries it will sell for storage use.
With both battery plants wholly owned by Ford, it sets them up for that new income stream
that Bill Ford has been desperately searching for for since the Premium Auto Group days.
Interesting if this pans out….
BYD has another pickup thats bigger than
Shark 6 but maybe not Full size like F150
Would be interesting if Ford signed up with BYD,
probably the largest battery maker in China with
huge vertical integration.
Yea, exactly. Jimbo touted this shortly after construction started for Blue Oval City:
It's a marvel of simplification. The most important thing is to reduce the labor content, we're insourcing with batteries and things like that. The vehicle's [T3] designed in such a way - because it's second-generation - where we radically simplified the subassemblies. It's a really big change, the way this will be built. This will be a seminal moment like the Rouge was, but this is a new industrial revolution about clean, carbon-neutral manufacturing.
Another Ford big shot, Lisa Drake (who now leads the newfangled "Ford Energy" business), said this:
When you walk in, it will not feel like a plant that you've been in before. Our target was to actually build this truck more efficiently than the best truck we build - and we build trucks pretty well. It's more radical than just fasteners and brackets. We've done some systems engineering work where, essentially, we've taken pieces of the truck and reduced the design content down so it's a much more reductive design with less tooling and less people needed to install.
